R33 Gtst Carbon Fibre Door Sills - Now Ready!
  • Replies 171
Posted Images
Are they covered with a plastic protective coating like the nismo B-Pillar CF panels or are they covered with a clear coat? If so how many layers?
PSIParts; I'm no expert but it would seem that they are covered in quite a few layers of clear coat; definitely not like the coating on my Nismo B-Pillar garnishes.
Massive pile of PMs just sent out... all those on the list please reply promptly (before 24/11/2006)
This is a CUSTOM order; there most probably will NOT be another run of the R33GTST door sills ever (no I'm not joking, there just isn't any market for the R33 over there)
LOL you were the first to be listed as 100% HAHAHAHA
LOL .... guess I really should look at the first page more often!
* does the ditzy blond thing *
Even more names added as 100% confirmed.... thanks for all the interest guys; you're going to make Anna a happy girl!
:D
Guest
