R33 Gtst Carbon Fibre Door Sills - Now Ready!
  • Replies 171
Posted Images
R3LOAD status has been updated... thanks for the prompt payment!
thizzle; these sills can go on with one of two methods:
1) employing some extra heavy duty double sided tape; available from Bunnings (information courtesy of Slats on the R34 Sills)
2) transplanting the clips using super glue or some other form of adhesive... I did this and I must say it offers a more secure way of installing them. Also a benefit if you're like me and constantly accessing different areas of the car which you may need to remove the door sills for...
croat; payment confirmed - status updated thanks!
To everyone else, please get your payments in ASAP, like to get this order off to prevent unecessary delays~
Good luck breaking them - I've had mine in for the last few months with no special care (high heels, shopping, my boots) and they don't even have a scratch on them...
These would be even stronger I would imagine as the mould was made to the specs of the standard item and machine formed so yeah, it would be very strong.
And here I was thinking you were a dude.....high heels? hahaa
KamikazeR33; just let me know when you're good to go bro'
Trooper; the high heels belong to my GF but sometimes (just for kicks) I do try them on and go driving :P
PS: Photos added to the first post!
Guest
