Further information:
Nismo full body kit
Carbon rear wing
18" forged alloys (Nismo - $4400 set)
Adjustable suspension P1 ($3900 a set)
racing brakes endless
HKS GT2530 Twin Turbo
Big Injectors HKS 600cc with big fuel pump
High camshaft (Tomi) adjustable cam pulley HKS
Tomei Reytec full computer
HKS GT 2 way big intercooler
Koyo 2 way racing alloy radiator
Grex oil cooler kit
ARC oil catch tank
Nismo 2 way mechanical Deff
Titaniummn front pipe order made
Stainless steel exhaust Nismo
Exedy racing clutch twin plate
Big taco meter and 4 guages on dash
Blitz boost controller
HKS circuit attack counter
Recaro full bucket seat
Full roll cage
5 spoke racing harness
600 hourse power
• Price:
¥1,690,000
https://www.sau.com.au/forums/topic/136421-gtr-for-sale-in-japan/
  • Replies 49
Posted Images
yes it is race rally only ummmmmm looks good but donet know do you think jess will let me have too gtrs?
Oh its Andrew
What the hell do you mean "let you"?
She should consider herself lucky if you "let her" wash them both for you ;)
Dont give up that easy - wear the pants in the relationship :rofl:
Well what about this a bit better the price but looks boring
Cheap RAWS R32 GTR
Eligible for import under: SEVS
• Stock ID:
1485
• Year:
1992
• Month:
September
• Kms:
108,000
• Body:
Coupe
• Colour:
Red
• Engine:
2.6 Ltr Twin Turbo
• Transmission:
5-Spd Manual
• Condition:
Very Good
• Price:
¥947,000 FOB
$21,580 on road
For a breakdown of the total costs involved with importing any vehicle from Japan, check the Cost Calculator
This late model R32 GTR is available for import under the RAWS scheme. This means that although its a 1992 model it can still be imported if complied in a licensed compliance workshop.
These "RAWS" (sometimes called SEVS) cars are only eligable to be imported if they have had no substantial accident history or any other problems such as rust etc. This means that you are not only buying a later model GTR than others have recently been importing but you are also guaranteed of owning a straight, clean vehicle that will be complied to Australian standards in a Registered workshop by proffessionals.
RAWS compliance also covers servicing and tyres so when the car is delivered it will have had work such as this:
New Oil and Filter
Fuel Filter
Air Filter
Brake Fluid
Catalytic Converter
Carbon Canister
Genuine Brake Pads (if required)
Full tune and emissions test etc etc.
Features of this particular GTR:
Power Steering
Power Windows
Power Mirrors
Air Conditioning
17" Mags
Nismo front bar
Nismo rear spoiler set
Aftermarket Exhaust
APEXi SAFC
Race seat
Remote oil filter system (Grex)
Aftermarket Intercooler piping
Aftermarket Tube and fin intercooler
Air pods and heat shrouds
Strut Brace
Sports Suspension
Nardi Steering Wheel
Condition:
This 1992 model GTR has a few scratches on the door and the side of the front bar (as seen in pics). The stereo has been removed. General condition is excellent although the aftermarket parts will need to be removed prior to compliance so an allowance of between $400 and $800 should be made for removal of parts. This cost will depend on the compliance shop that is used when the car is imported.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
