which head is best?
Guest drift_me_silly
no msn on this machine, swapping labs in an hour...i'll try msg u then...where do you go to drift around here, who do you use for mech. work, how do you afford the sweet machines that are skylines? -i'm in the making of a career...namely mine...as i said.
in time.
If the rules are still the same, then the head off a larger capacity engine will cause a REDUCTION in C/R when fitted to an engine of smaller capacity (presumably the combustion chambers are bigger on the bigger engine). Now, this may allow you to run more boost, but the engine will be far less tractable 'off-boost'.
It was often the practice in the days of L-series engines to do things like fitting a L-16 head on a L-18 block to get a bit more compression.
If you are after serious grunt, then trying to fit the RB20 head on the RB25 seems more the way to go. Or you could simply port / polish a RB20 head for your RB20 block so that it breaths better.
Hi guys, RB25 and RB26 are 86 mm bore and RB20 is 78 mm bore. So if you try and put an RB25/26 head on an RB20 block you will have a mismatch in diameter of 8mm. The water jackets are in different places and, if I remember rightly, the oil galleries are different as well. That's why there are none around.
Want more capacity out of your RB20? Try an RB26 crank and rods and 4AGZE pistons, makes 2,336 cc's. There's a lot of info and discusion about this in the past on the forum, do a quick search. Also www.meggala.com has a lot of info as well.
Hope that helps.
Hi S13 Silvia, suggestions follow your questions.............
***What do you reckon would be a good price for rb26 crank and rods?
Shop around the forum they come up from time to time, prices vary from $200 to $500
**Is it possible to use the rb20 pistons with the rb26 rods?
Never tried it, I know the gudgeon pin is larger diameter in the little end of the RB26 conrod. You could either machine the piston for a larger gudgeon pin or bush the RB26 little end for the smaller RB20 gudgeon pin. Either would probably work OK, I would lean towards the former as a larger gudgeon would be better as long as the necessary machining doesn't weaken the piston too much.
**What's the availability like on getting the rb26 crank/rods?
They come up from time to time on the forum. Be watchfull, act swiftly, as they seem to sell fairly quickly, and have your money ready.
Hope that helps.
Hi drift_me_silly, check out the posts by JOnJOn he has a 2.4 litre RB20.
Watch the costs though, they add up and can easily exceed the cost of doing up an RB25DET.
Good luck, let me know how it goes.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
