which head is best?
Guest drift_me_silly
no msn on this machine, swapping labs in an hour...i'll try msg u then...where do you go to drift around here, who do you use for mech. work, how do you afford the sweet machines that are skylines? -i'm in the making of a career...namely mine...as i said.
in time.
If the rules are still the same, then the head off a larger capacity engine will cause a REDUCTION in C/R when fitted to an engine of smaller capacity (presumably the combustion chambers are bigger on the bigger engine). Now, this may allow you to run more boost, but the engine will be far less tractable 'off-boost'.
It was often the practice in the days of L-series engines to do things like fitting a L-16 head on a L-18 block to get a bit more compression.
If you are after serious grunt, then trying to fit the RB20 head on the RB25 seems more the way to go. Or you could simply port / polish a RB20 head for your RB20 block so that it breaths better.
Hi guys, RB25 and RB26 are 86 mm bore and RB20 is 78 mm bore. So if you try and put an RB25/26 head on an RB20 block you will have a mismatch in diameter of 8mm. The water jackets are in different places and, if I remember rightly, the oil galleries are different as well. That's why there are none around.
Want more capacity out of your RB20? Try an RB26 crank and rods and 4AGZE pistons, makes 2,336 cc's. There's a lot of info and discusion about this in the past on the forum, do a quick search. Also www.meggala.com has a lot of info as well.
Hope that helps.
Hi S13 Silvia, suggestions follow your questions.............
***What do you reckon would be a good price for rb26 crank and rods?
Shop around the forum they come up from time to time, prices vary from $200 to $500
**Is it possible to use the rb20 pistons with the rb26 rods?
Never tried it, I know the gudgeon pin is larger diameter in the little end of the RB26 conrod. You could either machine the piston for a larger gudgeon pin or bush the RB26 little end for the smaller RB20 gudgeon pin. Either would probably work OK, I would lean towards the former as a larger gudgeon would be better as long as the necessary machining doesn't weaken the piston too much.
**What's the availability like on getting the rb26 crank/rods?
They come up from time to time on the forum. Be watchfull, act swiftly, as they seem to sell fairly quickly, and have your money ready.
Hope that helps.
Hi drift_me_silly, check out the posts by JOnJOn he has a 2.4 litre RB20.
Watch the costs though, they add up and can easily exceed the cost of doing up an RB25DET.
Good luck, let me know how it goes.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
