the turning angle of the rears due to hicas i belive is no more then 1.5degrees
so i doubt youll have a problem
dont quote me on this though, its something i read
as for my car, my rear gaurge just sitting "on top of the wheel" so to speak (looking at it head on), havent had a problem with scuffing
then again, i have stock wheels (205/55/16)
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-268371
actually that's a good question about the HICAS...
i can't answer it, but am interested to know myself... how wide are your tyres though, and at this height, are they going to be sitting inside the guards? you may need the lip of the rear guard rolled back.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-268372
So, its already been lowered a bit?
Skylines don't take kindly to massive lowering. I think 1.5 - 2 inches is the most it will tolerate. Any more, and the geometry gets thrown into chaos, and it handles worse than if you had not lowered it.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-268467
its not so much the "geometry" of the car, its the negative camber u tend to get at the rears
together with the signiture axle tramp
plus
the excessive negative camber u get when u launch hard
mine has been lowered properly (whiteline full pack handling kit)
which wasnt much, think it was around 45mm (we made it lower) and hands like a dream (together with the azenis)
but thats besides the point of RON-15H question
will he scuff the gaurds
265 rubber at the reas, dood, thats PHAT...love it :P
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-268475
I have 235/45 on 17x7" wheels. Its lowered just at the front so sits about 10cm off the ground if u look at a GTR style bar.. no problem with wheel clearance when turning.
Rear sits a bit higher, but should have no problem with the small HICAS turn (yes, its only a degree or two). When i get it lowered (they're height adjustable Zeal coilovers) another 1" so the rears sit a bit more under the guard, should still be no probs.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-268660
if u accually look at your car the HICAS wont make a difference to gaurd rubbing, unless your car is about 2cm to the ground.
i have 255 17" x 10s and i still have room left, going to get some 285s.
it all depends what wheels you have and their offset.
the hicas swivels the rear wheels, only slightly and is extremly hard to notice.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-271468
I have TEIN coil overs all round, and also have 17 Inch wheels (not sure of the wheel widths, 8's front 9's rear I think...and tyres, I have 235/45 on the front, and 255/40 on the back, and I don't have a problem...except when the rear is higher than the front and I'm turning such as when reversing into my driveway. You will also have to get your guards rolled...about $60-$70 each.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-271813
I've forgotten where I read this, so it may be slightly wrong. Basically you turn the car on and turn the steering wheel left and right a few times and then pump the brake a few times. Some people say you have to then move the car forward, but I didn't have to do that. It should start the rear wheels moving (you'll feel it). If it doesn't work the first time, keep trying. You'll get some light flashing on your dash if you have error codes. I get error codes 22 and 32 - no idea how to fix them though.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-273188
I found the text I was thinking of. It's from The Sky's The Limit from SDU.
1. Switch ignition off, transmission in neutral or auto in Park.
2. Start engine
3. Very quickly (with a couple of seconds), turn the steering wheel left and right about 20 degrees from centre five times, and then pump the brakes five times, then press the brake pedal once more _this will enter diagnostic mode.
4. Drive forwards or backwards about 5 metres at a speed less than 10km/hr, this will enter full diagnostic mode.
5. The HICAS light in the instrument cluster will be flashing quickly (for normal) or will flash a code indicating any problems.
6. Long flash = first digit, short flash = second digit.
7. Diagnostics will return to normal after five minutes, or any speed over 10km/hr, or ignition is turned off.
HICAS Diagnostic Codes 1993 - 1999
11 HICAS control unit
12 HICAS motor power supply not present
13 HICAS motor output not present
21 Vehicle speed sensor not present
22 Steering angle sensor not present
23 Steering angle sensor neutral or not present
24 Rear main sensor input not present
25 Rear sub sensor input not present
31 Parking brake sensor input not present
32 (Auto) Inhibitor switch input not present
(Manual) Neutral switch input not present
33 Engine speed signal not present
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-273227
I forgot to mention, that when u lower the car it affects the camber...which in my case was really squat which made all four wheels sit like this...../___....and of course the tyres wore on the inside....something I didn't notice until the tyres were stuffed....to cut a long story short, it cost me around $600 to get the problem fixed. Just make sure that whoever does the work knows what they are talking about. You are now better informed....talk to several people at different places. Best of luck. Your car will look and handle great when the jobs done.
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-274252
yeah, i have had no problems with my car being low,
i have 245 18's all the way around and i have got the front guards half way down the tyre (nearly on the rim) and on the rim at the back. It handles like its on rails, BUT it does bounce a little (not too bad, i can live with it) my camber was a problem but i got a camber kit in the rear and now its the goods :).
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-274261
My rears have worn badly on the inside and I've just ordered a nice new set of FM901s so wanted to fix this before I wreck another set of tyres.
For anyone who is interested I just recieved a quote for the supply and fit of a rear camber kit (includes all 4 wheel alignment), price = $360.
Does this price sound about right?
https://www.sau.com.au/forums/topic/13649-lowering-gts-t/#findComment-291570
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
