Theoretically, the FPR will keep the pressure constant, in reality it does usually result in a slight increase in rail pressure and you car will be running a little rich
For the few $$$ it costs to get a car on a dyno, and check your AF ratios, it isnt a bad thing, alternately, put a fuel pressure guage on there, and see what its reading - should be 2.55kg at idle, 3.05kg at atmosphere. Most decent workshops will have a fuel pressure guage, will take maybe 15 mintues to check the pressure, if that.
https://www.sau.com.au/forums/topic/136579-quick-question/#findComment-2542460
Hey,
I replaced my fuel pump because my fuel pressure was dropping from 50psi to 40 on 10psi of boost and high revs.
I wouldn't have changed my fuel pump if I had enough pressure, so I can only think that you've changed your's for the same reason, or you were bored and/or wanted to change you fuel pump.
Because I changed my fuel pump to a Walbro, I now had 50 at full revs, on the current tune, and the afr's went rich, so I needed a retune.
So, If you change your fuel pump due to a dropping pressure at high revs, then chances are yes, you will need a retune.
https://www.sau.com.au/forums/topic/136579-quick-question/#findComment-2542861
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
