thanks for ur thoughts guys.... looks like i have a busy weekend ahead testing everything.... ill let u know how it all goes!!
cheers
I had a similar problem - turned out to be that the 'big' red connector that clips to the positive terminal of the battery had corroded terminlas which caused the voltage to cut in and out.
cleaned out the terminals - problem fixed.
https://www.sau.com.au/forums/topic/136582-hicas/page/2/#findComment-2563419
my positive battery terminal was like almost falling off so i replace that.... first 2 times i used the turbo timer there wasnt the usual problem and i was stoked... but now its just back to what it was like :( ive still gota try a few other things that u guy have mentioned.... thanks for ur input!
https://www.sau.com.au/forums/topic/136582-hicas/page/2/#findComment-2569869
my positive battery terminal was like almost falling off so i replace that.... first 2 times i used the turbo timer there wasnt the usual problem and i was stoked... but now its just back to what it was like :) ive still gota try a few other things that u guy have mentioned.... thanks for ur input!
Hey guys, I have the same problem as Kribside. I have checked the voltage that is being output, both over 13.5 (TT on and off). Any other possibilities? I ahve checked the battery and connections, all nice and tight and clean.
Cheers,
Dan :dry:
https://www.sau.com.au/forums/topic/136582-hicas/page/2/#findComment-2586673
