if i end up keepin the car and change the t51r is it possible to get an exhaust housing that bolts to my manifold??? eg if i get a t04z.. which has the t4 split pulse ... any chance of adapting some how.. what will i have to do, i dont really wanna part with my ss hks manifold.
**edit** after some searching, is this what i need???
http://www.hksusa.com/products/?id=828
thanks
Edited by MR MAD
https://www.sau.com.au/forums/topic/136595-hks-t51r-manifold/
Is your existing manifold split-pulse or not (I'm assuming that the flange isn't a T4 flange)
If it is split-pulse, you will need to try to find an adaptor plate (cutting off a split-pulse flange
then welding a new one on nicely is just about impossible, because of the middle part of the flange).
If it is not, and you must have a split-pulse turbo, then sell your manifold and buy one that's appropriate.
If it is not, and you can live without split-pulse then go for the T04Z in the .81 'normal' housing and you can pretty
easily have your existing flange cut off and the appropriate-sized one welded on.
Regards,
Saliya
