Batmbl Gb #3: Twin/split Dump & Front Pipes In One + 3" Hi-flow Catco Cats (optional)
hi, sorry changed my mind can I get the small body cat + the dump instead thanks...so that adds up to $600? will make payment by wednesday...cheers
  • Replies 113
just an update on the performance on these parts,
i got dyno info from a customer with a r33 gtst today, and after replacing the stock dump/front pipe and cat with the split dump/front pipe and catco metal cat, he got a increase of 32kw @ wheels. thats an excellent power gain, and it shows that our figures with the r32 gtst were also tested correctly, as we got an increase of 26kw @ wheels on our r32 gtst test car.
cheers
Cool, look forward to getting my split pipe and metal catco cat. Maybe I should see if I can get a power run on a dyno before I install them and after to see increase!!
put me down for a split dump pipe for r34 GTT coupe
out of curiousity how much saving are we getting (are the prices on your website freight inclusive??)
Is the only difference between the R33 and R34 pipes length? and how much difference in length is there?
I bought an R33 split dump a while back from you for a Stagea, and it does fit, but is a little too short, plus the stagea has the bracket that supports the pipe from the gearbox.
thank you for the payments guys. could all in the list who are still going ahead with the GB organise your payment to be sent by friday this week. this way most pipes will be sent out next week.
beastien,
hi yes the length is different (r34 is longer), about a 20-30cm difference, and also the pipe curves differently toward the cat and the cat side flange comes on at a different angle. the r34 pipe also has a bracket welded to it, whereas the r32/r33 pipe doesnt.
cheers
beastien,
cheers
Cheers mate, sound like the R34 pipe wouldn't fit at all then, might just have to get mine lengthened a bit, it's only short by about 20-30mm.
pipes will be sent out early next week. many of you will get them before next weekend. i will keep the list updated as the parts get sent.
cheers guys
hey batmbl,
just paid then from Anz bank it should show up tomorro i guess because i got in before 5
thanks
Simon
pm sent with post details.
hi Batmbl,
curious do we get gaskets to fit the cat to the front pite and the cat to the catback? also the gasket to the wastegate and turbo?
cheers
SKY 34,
If you have purchased a cat, the cats come with 3" gaskets, so you would use them for the front pipe side and for the cat-back side. The turbo gasket is not supplied, but 95% of the time the original nissan gasket is re-used unless its leaking or not in good cond.
cheers
Guest
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
