Batmbl Gb #3: Twin/split Dump & Front Pipes In One + 3" Hi-flow Catco Cats (optional)
  • Replies 113
Holy pain in the ass batman
I cant even get my old one off so I cant say if it fits or not yet
can only get five of the 6 nuts off
is there a trick to getting a spanner to the nut in the middle closest to the inner guard ??
Mines got an aftermarket dump pipe on at the moment and its proving to be very difficult to remove
Just be careful, we snaped off the top one in the turbo exhaust manifold, now we have the wonderful task of removing it :) Have you tried spraying WD40 or similar and letting it sit for an hour or so, this may help a little. ;)
The quality of these split dump pipes and metal high flow catco cats are excellent, I can highly recommend them if any one is considering a purchase!!! :O
SS8_Gohan - Maybe I am just being a bit fussy, it does fit but just sits too close to the body at the cat end for my liking, but this problem is easily fixed and I am not complaining, but that could also be because I have an R34 Series 2 sedan, I dont know if they would be different to coupe's or Series 1's??
Ay every one i just perchased a catco 3" metal cat and was just wondering has anybody had trouble with the 5" center.. like dose it scrape on everything etc.. cauz currently my dump pipe is the one that scrapes on speedhumps..
hmm... i've finally paid for my split pipe, not too keen on this "not fitting quite right" business :laugh:
If you are referring to my experience, it fitted perfect, i just had to get a slightly shorter bolt for one of the holes (or cut a little off the end of the old one).
I also found that with the new dump and metal cat, my ground clearance was better than with my stock cat.
I got it fitting by a workshop though, cost $80 or so. Well worth it.
Finally got it on
wasnt so bad after all
had to go buy a stubby spanner set to get to the bloody nuts
but it fitted straight up
and after driving it i wouyld say it does spool up alot faster now and power feels more linear (smoother)
referring to other R34 owners ;)
EDIT: oh... got the pipe... now for the catback (already have a BATMBL 3" cat) HKS Super Dragger anyone? ;)
Fugi,
the cats being made up today and should be delivered to me on Monday or tuesdays at most. i will get it sent out then and you should recieve it by end of next week as it will be sent from syd.
cheers
hi guys
i have PMd all those registering interest in another GB. i might be able to arrange a small GB if most interested parties want to go ahead.
cheers
Guest
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
