I have an R33 GTR fibreglass bar that I was going to modify to fit my GTS25t track car, but it is going to be too much stuffing about for me.
$250 pick up from South Morang. Can arrange shipping at your expense. Comes with mesh.
Don't need it for my GTR as I have an original spare.
It will fit in the front of an R33 with some acrobatics, and yes you can drive the car :laugh:
Perfect for anyone called Scotsman :happy:
Cheers
Geoff
https://www.sau.com.au/forums/topic/136608-fs-r33-gtr-glass-bar-250/
  • 1 month later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
