Item:
1986 Series IV RX7 Turbo
Brisbane, Northside
Website:
N/A
Item Condition:
Reasonable to Good.
Sunroof has some rust bubbles under the paint, and the passenger side door has a very minor scrape/ripple in it, however, unless you know what you're looking for, you can't notice it (it's shown in the pics above, but as i said, very hard to see). Was quoted $800 to repair and respray from reputable panel shop.
Not sure if engine has been rebuilt or not, we have only had the car about 1 1/2 years, and it's just been used as a daily driver to drive to work and back in that time. It still runs fine, pulls hard etc, but could probably use a bit of a freshen up at some stage in the future.
The car has been priced taking into account the above condition of the vehicle.
Reason for Selling:
Want Something Different
Price and Payment Conditions:
$8,499 ono
Extra Info:
1986 Series IV Mazda RX7 Turbo
Red
13BT
Manual
AUSTRALIAN DELIVERED - Easy Insurance
~260,000km
3 Months Rego Remaining (Due in December)
Will Supply Roadworthy Certificate
$8,499 ono, or will swap for FTO, SW20 MR2 or Skyline with cash adjustment
Its fairly Standard with only the following mods/additions:
*Alarm & Immobiliser
*Short Shifter
*Autometer 'Phantom' Boost Guage
*TCC Work Type III Atmo BOV
*TurboXS Manual Boost Controller
*17" Wheels
*Suspension (I'm not sure what type it is, i just know its very low, and stiff)
*Front half of the exhaust appears to be aftermarket, with a standard rear
section
The paint on this thing is in fairly good condition, with only a few spots of rust starting to appear on the sunroof (very common), and just general age... the pics will give you a better idea of the condition of the paint though.
Pictures:
Contact Details:
Please contact me by either Email:
jwgeh @ tpg.com.au
or by phone
0402 202 978
https://www.sau.com.au/forums/topic/136649-1986-series-iv-mazda-rx7-turbo/
this your car jason?? i swear i seen it for sale on boostcruising about a year ago? same pics an all.. i was guna look at it for a mate of mine.
Guess they all look the same standard tho. Good car, looks clean ;)
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
