Ive just got a couple of z32 afm's for my gtr and when i went to change them over the plug doesnt fit. is it a matter of undoing the 4 screws and changing the plug over or do i need to do something else? probably a dumb question but any help would be greatly appreciated!
https://www.sau.com.au/forums/topic/136654-z32-afm-on-rb26/
Someone must be able to help me? All i really need to know is how do i get my new z32 afm's to work on my car?
I bought my genuine Tomei Z32 AFM plugs from Just Jap - They usually have heaps in stock
http://www.justjap.com/parts_nengine.htm
Hope this helps
https://www.sau.com.au/forums/topic/136654-z32-afm-on-rb26/#findComment-2540620
yeah the apexi 80mm kit is an option for gtr users who want to switch to z32s but as most gtr owners would realise switching from stock afms to z32s is a costly exercise. almost $800 easily.
z32s - $350 each new
80mm pods - $90 - $120 each
afm to pod piping - $200 odd
silicon joiners - turbo duct to 80mm - $100 maybe???
do most retain the stock turbo ducts and then use joiners or replace the turbo ducts as well with 80mm suited items?
https://www.sau.com.au/forums/topic/136654-z32-afm-on-rb26/#findComment-2541191
Thanx again paul. I wish someone had told me it was such a costly exercise, everyone ive spoken to just says put the z32's on they flow better and you'll be able to get more power out of it. My own fault i guess for thinking that anything on a gtr would be cheap and easy. Can anyone tell me where i could get a adapter kit from?
https://www.sau.com.au/forums/topic/136654-z32-afm-on-rb26/#findComment-2545168
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
