My mechanic told me that 2 common things that cause bad fuel economy on skylines are the 02sensor, and the ecu temp sensor.
changed my 02 sensor a while ago, no improvement.
so is the temp sensor worth trying?
i think they're only about $50.
  • Replies 56
Posted Images
It sure can, if it is telling the ecu the engine is cold, it will always be using enrichment that isn't needed.
But all these sensors are easily tested for correct operation.
You don't just go changing things unless you like wasting money.
Two ways you can check it.
Firstly by disconnecting the plug and using a multimeter measure the resistance across the two terminals at the different water temps.
Spec is
20deg 2.5k ohm
80deg 0.3k ohm
Second way is to measure the voltage between ecu pin 28 and earth at the different water temps.
Spec is
20deg 3V
80deg 1V
As long as the test results are somewhere close to the spec it isn't faulty.
Hope that helps.
ive never seen a water temp sensor cause bad economy
if u want to test it, unplug it and drive around for a week
the car will be fairly upset. mind wouldnt even start with a shagged water temp sensor. so id be suprised if yours would work, but get crap economy.
How maney k's are you doing with 10l or a full tank and what 98 fuel are you useing, try shell optimax I put bp in car and the economy was bad
so try shell :nuke:
Edited by RB SANDY
I know mines a prehistoric R32 but mine would start and run ok with the water temp sensor disconnected.
I ran in to fuel economy problems a while back. All of a sudden dropped from mid to high 400's to 350km's per tank almost overnight.
Replaced o2 sensor with new item, had already replaced water temp sensors and they were reading fine on the pfc h/c. I replaced injectors and bang.. fuel economy was back. :)
Driving style also has a little to do with economy. With mine at least it makes a considerable difference. If I change up a shade over 2000rpm I get pretty damn close to 500km's per tank. If I stretch out the gears a little to 3000rpm with light throttle fuel economy hangs around the low 400's.
The odd boot here or there doesn't appear to make a noticable difference but if always up on boost and booting it it does and I only just scrap in at 400km's per tank (~50-52litres).
The RB20DET however, didn't seem to matter how I drove it, always returned 450-470km's per tank.
I feel like a broken record. I've said that so so many times. :nuke:
Spec is
20deg 2.5k ohm
80deg 0.3k ohm
Spec is
20deg 3V
80deg 1V
Hope that helps.
that helps alot. thanks man. will check that out.
so try shell :D
10.9L/100kms using Boost98. Works good, hella cheap too. Stockish R32 gtst.
so try shell :D
i'm getting about 15L/100kms. BP Ultimate 98.
Ive tried mobil, caltex, but not shell. keep hearing so many bad things about optimax.
At the end of the day, highway vs city/short trips, makes a huge difference.
that's why u get some R33 owners claiming 500kms to a tank, and others getting 250kms.
Will be hunting down a cheap used safc2 (anyone selling???) to fit and tune soon, but i want to make sure the temp sensor is doing its job first.
The Temp sensor is one of the vital reading's the ecu requires for fuel consuption!
Do the check as described above with a multimeter!
If it's out of spec replace it.
Cheers
Josh
do i keep the car running when measuring the resistance across the temp sensor terminals?
or motor off, ignition on?
or other ??
also, just to verify, this is the sensor i'm checking, right ?
I do all local driving. ZERO highway.
Driven correctly the 3ltr returns the same fuel consumption as the rb20det.
R33's for what ever reason tend to have considerably worse fuel economy compared to the little old r32's. Maybe its the greater weight, maybe its the vct or something who knows.
or other ??
disconnect the plug and measure the resistance on the engine when its cold (first thing in morning), water temp will be around 20degC then.
then again after driving the car and its up to normal operating temp disconnect it and measure the resistance. operating temp is around 80-90degC.
all test with engine off.
If you prefer to measure voltage you will need igntion on and the connector plugged on.
I tested the resistance at the temp sensor terminals.
2.85k ohms when cold/sitting overnight.
0.31k ohms when warmed up/after 15min drive.
so it looks good to me.
cheers man. thanks for your help.
if anyone is selling a used safc2, cheap, PM me. :angry:
if you do alot of short drives as opose to afew long drives fuel economy will suffer big time, just recently i moved closer to work so im only a 10min drive away so if all i do is drive to work my car is always running the richer(cold engine) maps as it doesnt get much time to warm up and my fuel economy has dropped from 450 odd km to 350 odd km's
Which is why its especially important to run a genuine thermostat as they get the car up to operating temp and out of the water temp correct table within 1-2km's.
Otto, if you run a pfc you can lean the water temp correct table out to all buggery until the drivability begins to suffer. I was able to take out a considerable amount of correction. I've seen a few maps from different tuners now and find it interesting they almost never touch the water temp correction table.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
