Lightweight Flywheels For 32 And 33 Gtr And Gtst
Hi Guys,
I am going to get a lightweight flywheel for the GTST, so I talked to John at UAS and as it happens he has just bought a shiatload and suggested that we might be able to do a group buy on these things.
A lightweight flywheel is a great addition to your skyline and gives some much welcomed throttle response. Plus they are much stronger than factory cast flywheels which have been known to explode, especially when used with aftermarket clutches, and in a launching/drag racing environment. So even if only for the safety of your limbs these are worthwhile.
This GB needs 10 buyers to get off the ground. It will be open until the end of October. Flywheels can be collected from Unique Autosports (Castle Hill, Sydney) and they can also do fitting (please contact them for price). When you do change the flywheel I'd also reccomend fitting an upgraded pivot (available at UAS) and a needle roller spigot bearing (also from UAS). Both these items will be discounted if you are purchasing a group buy flywheel.
Note that the factory skyline flywheel is over 9kgs and is cast iron. when they fly to bits (and they do) it can be devestating. ask benm who had his one fly appart at around 7000rpm which wrecked his engine, gearbox, and lots of bits in his engine bay. He was lucky it didn't tear through his body.
Here is some info on the flywheels available in the group buy.
Fidanza Flywheels
Alloy 6061 T6 with 1045 steel friction plates replaceable and 1050 steel, heat tempered ring gear, stepped dowels 5kg $510
Chrome Molly Light 6kg $410
Super Light Chrome Molly- 4.8kg $450
Freight is $30 Australia wide
Needle roller is $20 (normally $25)
High tensile pivot is $40 (normally $55)
Also available in the Group But is a one piece teflon/stainless steel braided clutch line, normally $120, GB price $105
These fly wheels come with loctite, locating dowels and ring gear. The Chrome Molly ones come as one piece. They are neutrally balanced.
UAS recommend the Chrome Molly flywheel as they are stronger and people have had issues with clutch bolts stripping thread on alloy flywheels with alloy clutch bolts on occaision (something to be carefull of if you choose alloy).
All three type are currently in stock.
Personally I'll probably go with the Chrome Molly 6kg one as it's a nice balance for a street car. Going too light can make the car a little tricky off the line, especially if used with a bitey clutch. For a race car though the super light would be perfect.
Here are some pics of what they look like:
Chrome Molly 6kg
Chrome Molly Super Light 4.8kg
Alloy 5kg
Braided clutch line
High tensile pivot
Needle roller bearing
Please contact Unique Autosports if you have any question about fitting etc. and if interested post up which one you need, and for what type of skyline.
UPDATE:
Ok, here is the list:
NV-01 needs:
Chrome Molly Flywheel
Needle roller
High tensile pivot
Freight to Brisbane
Beer Baron IN
Eug=maybe
Now, we have got a few more dudes in this from off the forum so it looks like we can go ahead anyway. I'll firm this all up in the next day or so. ;)
  • Replies 50
I assume this is a typo:
Chrome Molly 1045 Light 6kg $410
CrMo steels are AISI 4xxx series (eg 4130, 4340).
1045 is a medium carbon steel (0.45% carbon) with few other alloying additions, although it's perfectly suitable for flywheels.....I've run one in Z for many years ;)
thanks for the feedback AWDMAT.
The alloy ones do have the advantage of being able to replace the friction surface i guess too.
SteveL, I must confess I'm a bit noob with metal types it must be a typeo, as they are definately chrome molly steel. I'll check up on it.
I'm side by side with my mates car will a lightweight flywheel help me win the
drag because it is somthing I will change any way.
any idea if the flywheels differ from an R33 GTS25 to an R33 GTS25T??
the JUN one from perfect run says they are the same:
http://perfectrun.com.au/performance%20par...oriflywheel.htm
but the cusco one has no mention with regards to NA...
are you able to chase that up? and how much for shipment up to brisbane for the super light, including the upgraded pivots and needle roller spigot bearing.
cheers
eug
hi mate, it sure will. >_<
Hi there,
I may be interested in,
Needle roller
High tensile pivot
Freight to Brisbane
$500..will have to see how the funds go later on?
All for an RB20DET From a GTS-T
Edited by NV N01
Hi mr Gilly. I will have to check for you. I would assume it will fit as RB25/RB25NEO crank is the same bolt pattern, the only question would be the offset but i would think it's the same. in fact most RBs are the same the only difference being clutch operation. some pull type, some push type. but this doesn't have a bearing on flywheels.
sorry mate no flywheel on an auto, they just have a ring gear thingy for the starter to engage on.
I got one of these from John a while back (mild steel not chromoly), it is nice and light and has taken the abuse well (checked out by an engineer no sign of hairline cracks etc)
and I'm certain it gets plenty of it!
Baron, I've got a question for ya.
That 4.8kg chromoly one looks very scary. If you look at the 'weakest' points in between those holes, there isn't a lot of metal there.
How strong is it compared to the stock one?
I've heard really nasty stories of flywheels falling apart (like benm's one) and actually entering the cabin taking out legs, people, heads, whatever happens to be in its way.
agreed... the 'super light' one looks like the 'light' one just drilled out more. and if it is, i'd say it would be weaker than the 'light' one...
Can someone start a list off who is in?
I have no idea how many people are in but apparently we need atleast
10 people..
Also, does any1 know where the High Tensile Pivot go's?
Guest
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
