Ive got a R34GTT engine in my R32GTS-T, just got it started, problem tho, when car is cold it runs fine, no problem at all, except that the temp gauge doesnt work, thinking it could be that the engines sensor using other data then the standard one. Now when the car gets warm, it idles perfect, but when you floor the pedal, and as soon as the car comes into boost it starts to run bad, like on 4 or 5 cylinders, same happens if i pull out the temp sensor for the Ecu, just get higher idleing then. ive checked the spark plugs they seems fine, anyone got a tip on this?
https://www.sau.com.au/forums/topic/136669-varm-engine-runs-bad/
well firstly on the temp gauge thing..
there's 2 temp sensors.. one for the ECU and one for the gauge
if you follow the upper radiator hose into the engine just in front of the intake manifold you will see 2 plugs. are they both plugged in?
now as for the "running bad" that you describe.. i can suggest to check the following common things that cause missing like that
- coils (may have a faulty one or may have a crack on one of them)
- air flow meter (may have a worn contact in it or it might not be plugged in properly!)
best of luck
Warren
yeah they are both plugged in, i tried to earth the one for the temp gauge and it went to the top, if i check the plug for the gauge it has a small +voltage when not connected but when i connect it to the sensor i get nothing when i check with volt meter.
i checked the coilpacks, they look as good as new, anyway to test em?
gonna check wiring on the the Afm, i checked the soldering for the connector but it seemed fine
for the connector, you have to check inside the AFM
you can open it up and ckeck the joints that exit the AFM. there are 4 solder joints that are known to fail over time
also, the coil packs can sometimes look ok but have a fine hairline crack. try covering them with silicone or epoxy before putting them back in
cheers,
Warren
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
