Hey guys, currently got a problem with my r33 gtst.
It is missing when it is under load. If u rev it when the car is stationary it will not miss if you gradually build the revs up. But if you rev it once then go at it again before the revs come back down it will miss.
It misses when you are driving aswell if you start to put the foot into it. The car also blows out a puff of black smoke when it misses.
Its not the coil packs and its not my inlet piping (cant find a leak).
Has anyone got any ideas as to what it could be?
Im think maybe i should change my plugs anyway but im doubting it would be the problem.
Thanks, Mike.
https://www.sau.com.au/forums/topic/136683-r33-missing/
Hey guys, i changed the plugs today and it made no difference at all. My AFM is only like 6 months old and has been used stuff all so i dont think that it is that. Is it possible to be the o2 sensor?
Anyone else got any ideas?
Thanks, Mike
https://www.sau.com.au/forums/topic/136683-r33-missing/#findComment-2543572
Thanks, Mike
02 Sensors only "Trim" your fuel mixture.
I would be inclinded to be looking at the Ignition system (black smoke indicating unburnt/rich fuel). But thats not to say its not an injector problem. Biggest thing is to test things when you can replicate the problem - hence the use of dyno's for diagnosis. Its one of those things - to the untrained eye you could spend a long time looking for it.
Cheers
Sumo
Edited by Sumo
https://www.sau.com.au/forums/topic/136683-r33-missing/#findComment-2543858
it started missing after i completed a whole heap of work. ive had stuffed coil packs before and i know the symptoms of them.
car should be going on the dyno sometime this week but i kinda wanted to get rid of the miss before the dyno.
Thanks, Mike
https://www.sau.com.au/forums/topic/136683-r33-missing/#findComment-2544105
hey guys do u think my problem could be my TPS?
No!!! 99.999999% of the time a missfire will be due to a bad plug (wrong heat range, incorect gap, cracked insulator) or a bad coil (cracked coil boots, foreign particles around plugs/boots and or excessive oil or the coil itself). Also overly retard ignition can casue missfires along with about a thousand other things - check the basics first always!!!!
Can somebody please do a missfire check list and wirte it into a sticky - I swear we see this post every week.
https://www.sau.com.au/forums/topic/136683-r33-missing/#findComment-2546595
I have similar problem my car falls into a very big hole at full throttle over 4000rpm. I did also have a misfire but a dodgey coil pack was the cause of that. i have exchanged igniter module with a new one still no luck my next step is AFM. if no luck im getting an aftermarket ecu and split fire coils and hope like hell it fixes itself
https://www.sau.com.au/forums/topic/136683-r33-missing/#findComment-2550723
hey guys 99% sure its not my plugs or coil packs. It misses at any RPM. Ive changed my plugs and gapped them at 26 thou.
Also my injectors are only a couple of months old and were working a few weeks ago, so they should be fine.
I will check the CAS and timing though.
Thanks, Mike
https://www.sau.com.au/forums/topic/136683-r33-missing/#findComment-2554735
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
