Hey!
Just wondering if anyone knows any Import Wreckers in Brisbane? (Mainly after import wrecking yards with Skylines) If so, could you please post it here with as much information as you know, such as:
Name:
Address:
Phone:
Overall Rating /10:
Thank you!
https://www.sau.com.au/forums/topic/136699-import-wreckers/
Try these guys
http://www.asianautospares.com.au/
Asian Auto Spares. Great blokes down there.
Would rate them a 9/10
One of their blokes that works there races a red silvia out at qr. Top bloke and a quick car. Not that it has anything to do with it, but yeh...
Edited by r33_racer
https://www.sau.com.au/forums/topic/136699-import-wreckers/#findComment-2541419
Cheers buddy! I was going to go there tomorrow morning not sure if they are open though, hope they have what I'm after!
Edit: Just reading on there website, they're only open Monday till Friday 8am till 4:30pm.
Edited by R33MidnightRacer
https://www.sau.com.au/forums/topic/136699-import-wreckers/#findComment-2541422
useful to the 95% of people that work during the day..
all the import places are the same.. who gives a crap whether they were closed say mon-wed if at least they were open on saturdays.
I called them today, to see if they were open and when I called at 8:30am they were, the person I spoke to said they close at midday. There website isnt up-to-date I guess.
https://www.sau.com.au/forums/topic/136699-import-wreckers/#findComment-2541819
Try these guys
Yeah they are really good, they have a lot of engines and parts lying around. We salvaged a genuine nardi steering wheel of a series 4 rx7 half cut for $20!
Edited by gibbau
https://www.sau.com.au/forums/topic/136699-import-wreckers/#findComment-2545517
All Automotive Import Parts at 17 Mile Rocks..
Near the Rocks Riverside Park..
You will tell which one it is..
They've got a lot of crap.. are usually open on Saturdays and sometime Sundays..
Depending on what is happening
https://www.sau.com.au/forums/topic/136699-import-wreckers/#findComment-2559632
  • 1 year later...
Hey!
Name:
Address:
Phone:
Overall Rating /10:
Thank you!
i have a r33 skyline that ia werecked but ,moter,gear box and diff are fine
https://www.sau.com.au/forums/topic/136699-import-wreckers/#findComment-3913660
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
