How do I know If my Cam Angle Sensor is In right position?
Is there a way of checking it?
Just wondering as my CAS has been moved a few times and I am still not 100% sure that its in the right position , If theres anyone outhere that could help would be much appreciated....
I have searched about this topic and most of the replies are unclear.
Thx In advance :nuke::)
You need a timing light for starters you can buy them from autobarn type shops. Then you need to connect the 2xpower leads to your battery and the third lead goes onto number one HT lead that connects the your spark plug. Number one cylinder is at the front of the engine IE: closest to the front of the car. Make sure you hook this up the right way, there should be an arrow on the connector for the light indicating which way round it should be hooked on. Once its all connected up get a appropriate spanner to loosen the bolts on the CAS just enough so it can e rotated but not so much as it will turn by itself. Next start the engine and point the timing light down onto the crank pulley. There will be a series of marks on the timing cover behind the pulley with numbers on it IE:15BTDC,10BTDC,5BTDC,TDC, etc. There is a corresponding mark on the pulley itself that when you shine the flashing timing light on it, it will point at one of the marks on the timing cover. With the car idling twist the CAS until the mark lines up with 15BTDC. Then tighten up the CAS and recheck it.
Good luck hope i helped
Deren
Edited by Godzilla32
I have done this already , to find that the timing mark was was fluctuating and was unclear how to stop this I'm pretty sure that theres a way of making the mark stay at one point this is my main concern! :D:no:
could just be an idling problem. make sure you're at operating temp when doing this and check all idle related components are working properly. go through and search the DIY section on how to fix these yourself.
  • 1 year later...
ok from what i am aware of, full clock wise is default position... just fixed my rough idling r33 and now she sits at 650rpm just perfect!
i could be wrong but it is my understanding that most skyline's should idle much higher then that. more like up around 800-850
as above
the cas controls that base timing. it should be at 15deg BTDC which is usually about in the middle of its range of movement..
i think u just must have typed the wrong thing. The CAS does not affect base timing. it affects ignition timing.
theres a sticker under your bonnet that tells you what idle should be. i think it's 700 +/- 50 from memory
mine idles at 700.
edit: it's 650 +/- 50
Edited by Munkyb0y
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
