How do I know If my Cam Angle Sensor is In right position?
Is there a way of checking it?
Just wondering as my CAS has been moved a few times and I am still not 100% sure that its in the right position , If theres anyone outhere that could help would be much appreciated....
I have searched about this topic and most of the replies are unclear.
Thx In advance :nuke::)
You need a timing light for starters you can buy them from autobarn type shops. Then you need to connect the 2xpower leads to your battery and the third lead goes onto number one HT lead that connects the your spark plug. Number one cylinder is at the front of the engine IE: closest to the front of the car. Make sure you hook this up the right way, there should be an arrow on the connector for the light indicating which way round it should be hooked on. Once its all connected up get a appropriate spanner to loosen the bolts on the CAS just enough so it can e rotated but not so much as it will turn by itself. Next start the engine and point the timing light down onto the crank pulley. There will be a series of marks on the timing cover behind the pulley with numbers on it IE:15BTDC,10BTDC,5BTDC,TDC, etc. There is a corresponding mark on the pulley itself that when you shine the flashing timing light on it, it will point at one of the marks on the timing cover. With the car idling twist the CAS until the mark lines up with 15BTDC. Then tighten up the CAS and recheck it.
Good luck hope i helped
Deren
Edited by Godzilla32
I have done this already , to find that the timing mark was was fluctuating and was unclear how to stop this I'm pretty sure that theres a way of making the mark stay at one point this is my main concern! :D:no:
could just be an idling problem. make sure you're at operating temp when doing this and check all idle related components are working properly. go through and search the DIY section on how to fix these yourself.
  • 1 year later...
ok from what i am aware of, full clock wise is default position... just fixed my rough idling r33 and now she sits at 650rpm just perfect!
i could be wrong but it is my understanding that most skyline's should idle much higher then that. more like up around 800-850
as above
the cas controls that base timing. it should be at 15deg BTDC which is usually about in the middle of its range of movement..
i think u just must have typed the wrong thing. The CAS does not affect base timing. it affects ignition timing.
theres a sticker under your bonnet that tells you what idle should be. i think it's 700 +/- 50 from memory
mine idles at 700.
edit: it's 650 +/- 50
Edited by Munkyb0y
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
    • Light should be a pressure switch, not a sensor.
    • The pressure light likely has a different sender to a pressure gauge, its been too long for me to remember for sure. Just have a look for another sender down near the oil filter. If you are confident in your rewired pressure sender reading correctly, you can be pretty sure it is just the dash light's sender failing, it is a pretty common thing.
    • It would be nice to see the result, but instagram is a click too far
    • That is a series 1 front end (grill, bumper, headlights). I'm not sure if you are trying to confirm if your whole car is series 1 or just the headlights, but the build date and vin# on the plaque in the engine bay would be the best reference for what it was when it left the factory (noting a lot may have changed over the years)
