ok, found the problem.... long story short, dodgy multimeter!!! lol (thats why you dont buy cheap ones... lol)
and yes i did throw it against a wall!!! lol
next question, is there a factroy hole in the firewall somewhere where i run the power cable for the amp?
and the parcel shelf - how do you take it out? I have these wierd metal brackets right across the speaker holes and they gota go if im gona put speakers in there.
I found the rear speaker cables, they were hidden near the speaker holes and sticky taped ;)
Im planning on finishing this today so i'll post up some pics once its done!
I found out the hard way, you need to remove the rear side pillar cover as pictured. I didn't at first and broke the seat belt bracket. Its a hard pull but it should come out.
I foud the hole I found the hole!!!! haha!!
FIIINNAAAALLLLYYYYY its done!!!!! :glare::) and i didnt break anything!! bonus!!! :O
Thankyou for all your help guys!!!!
heres a few pics i quickly took with my phone, i'll try take some pics tomorrow morning with my camera in daylight....
I took one of the pics with the face opened when you change cd's, it just clears the gear lever when in 1st, 3rd and 5th which im rapt about!!! i thought it was going to knock the gear lever!!!
post-30514-1160903971.jpgpost-30514-1160904084.jpgpost-30514-1160904119.jpgpost-30514-1160904167.jpgpost-30514-1160904199.jpg
good one...very nice...is tht the new JVC double din unit?
cheers!
yup!! dun know how new it is, but yeah I prefered the double din over the single slide out ones.
thought i'd pop up a few pics of my new baby too!! :O only had her for about 3-4 weeks or so... fair upgrade from a 31
One question..... it picks up radio stations really bad!!! any reason that anyone can think of??
cheers!
thought i'd pop up a few pics of my new baby too!! :) only had her for about 3-4 weeks or so... fair upgrade from a 31
waht radio?
  • 1 year later...
know its a bit late but i just put a new stereo in to fix the shitty radio reception. The reason is in japan they have 2 antenna's 2 different signals or something that's why the stock units have that fm diversity on it and a 2 pronged antenna plug, when i pulled mine apart the moron that installed the signal booster hooked it up to the wrong antenna. only 1 antenna will work u just have to test them. Works perfectlly now.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
