Find a manifold made from stainless steel, with individual runners and a wastegate flange angled into the exhaust flow. Make sure the runners are seperate where they bolt into the block to allow them to expand. Proper design > brand.
Why stainless, steampipe ones dont crack wheras stainless ones are far more prone
It has far les to do with it being stainless. Its actually a function of not the metal but the fabrication technique. There isnt a reason why you cant have the best of both worlds
stainless goes brittle after its been exposed to too much heat. Its the same when welding it. It seems to be hard to find a properly constructed manifold these days. Plus the stainless manifolds go dull and grey from the heat and only look good (bling factor) for the first month or two. It wouldnt matter if it was totally wrapped though. Without the wrapping the mild steel radiates less heat and helps keep underbonnet temps down where the ss radiates it massively if not wrapped, so i guess a wrapped ms would be ultimate. That was the biggest difference i noticed when changing from ss to ms manifolds, the radiating heat. Not only that but with the 6boost manifold we saw a straight out 300-400rpm earlier boost and power incline. That was the biggest thing our tuners complimented on when the car went back to them.
Hows that when the coefficient of thermal expansion for stainless steel is like 10 times that of mild steell(depending on the grade.
Thermal expansion? Ok, but its not an issue. The amount of bends in a manifold allow it to grow. Its only an issue if you have a long length of striagh tube which is fixed at both ends and it cant grow.
So good point, but my 2c is thermal expansion is not an issue. I worked for about 5 years in the specialised welding insudtry, and still work in a related industry. So whislt i cant weld for sh1t, i know a good weld and have wokred with great welders. I have only ever seen a few manifolds that from a welding perspective cut the mustard.
General practice is pretty poor. Does the job, but not a good weld, and im sure would fail many of the xray and tensile tests etc required for it to become a qualified weld procedure as per AS requirements.
Steam pipe will work, but its a ball ache to get smooth internal bore. The right grade of stainless steel welded properly and isntalled with a bit of care will give you a light and great performing manifold....my choice should i need one.
Main advantage of cast manifold is you get to play with bore and tweak gas velocity. Tube doesnt give you that flexibility. But short radius and long radius elbows dont give you the same fabrication flexibility as tube.
Although all this talk of welding...thats another point. A good manifold will use mandrel bent sections with only around the collectors requiring welding...ala every racign manifold you see and manifolds liek Gibson and Nissan gave the R31 GTSR, or you see on a lot of drag boats etc
Are you guys serious? 304 grade stainless as an example is pretty easy to weld, crack resistant, low in thermal conductivity and long-term corrosion resistant. The only potential worry is the high coefficient of thermal expansion but that can be accounted for. In theory, and with a proper design, stainless should be one of the top candidates. If using mild steel you'd want to coat it with chrome or some sort of ceramic to help with corrosion resistance.
Edited by govich
no response to my email to 6boost. i really dont want to make an international call. are they typically responsive to emails?
More responsive to phone or SMS IME.
SMS should not cost you the world; but then again neither should an international call... particularly not
compared to the price of the manifold.
Regards,
Saliya
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
