I thought I'd get an idea of the engines health before spending big on a turbo upgrade. It was done at Allstar tuning in Brisbane and they seemed pretty happy with the results.
Compression
1-170
2-155
3-165
4-160
5-160
6-165
Leakdown
1-10%
2-20%
3-12%
4-16%
5-17%
6-10%
After a turbo upgrade my target is 260rwkw. Will the engine be able to handle it and should I be worried about cylinder 2?
Thanks in advance. :D
from memory.... spec for turbo rb's should be
all above 128psi
no more than 17psi variance
so your motor is within spec.. barely!
it sounds like it's getting to the stage where i would do a 'simple' rebuild, but if you can't do it yourself and have to pay someone to do it, wait until it get's really bad and do a full rebuild.
if it were me and i were running that much power i'd consider taking it apart, inspecting the pistons and bores (especially number 2) and bearings, give it a quick hone and some new rings and head gasket - (ie stuff you can do with engine in the car). If you need to pay someone to do that, may as well do everything while you're there though.
Damn, that doesnt sound good at all :D . Looks like I'll have to put off the turbo and suspension upgrade and spend the dosh on a rebuild. I might aswell get some forged parts and go for a higher power figure later on. Its driven daily but I wanted to build it for track days and hillclimbs. Off to do some research, might have to PM SK and see what he thinks.
Thanks guys.
after 100,000 and a GT30 on the side of mine, and all of my own tuning
all about 160psi
Biggest variance was 4 psi
leakdown was 3% across all 6 cylinders.
Man, 20% leakdown means its f**ked. Rebuild it now before you damage it worse but blowing a piston in half.
^^ True,
But if it's correct it has taken 92000 km's for the engine to wear to your results, do the math and you will still get a fair bit of milage before it goes! Keeping in mind the extra kw also.
Cheers
Josh
Yep spend all your $$ now on support mods and bolt ons... Then when the motor gets noticably tired you have an excuse (for the missus) to get it rebuilt. Rebuild it now and then try to justify support mods after.. Doesn't always go down too well. :(
Do they only do a "dry" leak down test?
You haven't put up "wet" leak down results, so I assume not.
Take it back and get them to do a "wet leak down test".
That will tell you if it's a valve seal problem or a ring seal problem.
If it's a valve seal problem then a simple (relatively) head service will fix it.
Post up the results "wet" leak down test and we will go from there.
:D cheers :)
to me it looks ok, compression test should be within 10% of each other, cylinder leakage should be no more than 20% (one is borderline). You have to keep in mind that with the cylinder leakage, most of the pressure goes through the ring gaps. As sydneykid said, it should be done wet as well, even a wet compression test will tell you if its rings or a valve sealing problem.
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
