post-19743-1160949703.jpgpost-19743-1159667422.jpgpost-19743-1159667066.jpgpost-19743-1159666374.jpgpost-19743-1159666704.jpgi have some parts im looking to get rid of as i will be selling the car;
PRICES DROPPED MAKE SOME OFFERS PEOPLE
CAN POST MOST PARTS OR PICK UP
WILL INCLUDE POST ON SOME PARTS
all parts good or very good or new condition and located in se melbourne.
ADDED-brand new low mount stainless steel tube exhaust manifold (with NEW crap gaskets)
hks copy,same with all these parts, selling due to selling me the car. $280ono price dropped
TO SUIT RB20DET OR RB25DET
1 x BRAND NEW genuine nissan exhaust manifold gasket for rb20det $75 ono
1 x standard rb20 cross over pipe with blow off valve $40 ono
1 x standard rb20 intercooler with pipes under guard and brackets $40 ono
1 x set of (2) coil over sleeves to suit any car with 50mm od struts, with springs $80
1 x set of r32 gtr centre gauges with plug and 2" of loom gc $125
1 x set of NEW whiteline adjustable castor bushes for gtst KCA331 $75 ono
1 x pair of r32 gtr nismo style front bar vents (fibreglass) $100 RELISTED
i will have other parts available in about a week and a half,
-standard r32gtst turbo in gc
Edited by DOUGMO
  • Replies 66
there are still in the packet,(it has been opened) but never been used or greased,
I can post for $10 extra
aight ill take it man, PM me your bank details and ill send you my shipping adress.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
