benm, the camera is only a little B&W CCD model, which I bought because it wasn't too expensive and would allow me to pilot the idea of mounting external cameras and mics. Re sound, I have already trialled mics in the engine bay and it's pretty good. I need to build a preamp before I can get the sound and video working together. Once I've done that I'll be choosing a colour camera.
Tex and I had been musing about it for a few weeks (ie "wouldn't it be cool if...") and then I thought hell let's try it, bought what I needed on a friday afternoon and made up the cables. Turned up 20mins late to dinner with a bit of a smirk until I spilled the beans and said I had onboard video and we tested it that night, then I brought it with me on the hunter cruise the next day. So it's very much a prototype :)
  • Replies 40
Originally posted by benm
Well if thats a prototype I want in on the real deal.
Prototype Costs ?
Expected final Costs ?
I believe the prototype was really cheap as chips, though Kinks will be able to tell you more.
No, the real deal is for us. :)
It's going to be quite a bit more expensive, because it's going to be a hell of a lot more elaborate. The camera alone will cost much more than the one Geoff used here... And the ideas I'm particularly keen on trying will call for a fair bit more hardware.
We've not really got a shopping list together, but I'm sure soon we will. :)
Re: sound, we have not only trialled mics in the engine bay with great success now (you will hear an example in my upcoming Hunter vids), but also at the rear bumper, above the exhaust. So far, things look very promising. :)
As Big Kev would say, I'M EXCITED!
Tex
The CCD I used was $110 retail, and I'll be looking at spending several times that amount just on the camera when this idea gets going.
As Tex says the real deal is for us. It's custom work, and will be a lot more elaborate eventually.
Originally posted by Tex
Yeah, yeah, Carlo tells me I'm very close to having heaps of hard disk space (I'm waiting for him to give me the hard drives I need, but he's a busy man :D).  As soon as that's sorted, I'll be editing like a mofo, for your viewing pleasure!
Will most likely update this thread with them, if Geoff doesn't mind. :(
Oh, and Mona, there's plenty more where that came from... ;)
Tex
uh oh!!!
Originally posted by JiMb0
Sweet .... Where's your footage Tex ?
In my pants. Why do you ask?
Seriously though, it currently resides on my camera, awaiting processing. :D As I said before, I am waiting to sort out some HDD space issues, so I can get cracking. Once the HDDs are installed and working correctly, I will now be able to edit pure DV format footage, instead of the other way I've been doing it 'til now, which involves importing in preview quality, editing, and then rendering the vid, at which point the footage all needs to be captured again, in full DV quality to be made in to the MPEG. Then it needs to be converted to DivX to bring the file size down to a more acceptable size.
It's time consuming! At least this way I'll cut one step out of the process, which should cut the total time spent waiting for the computer to capture vid by half.
Tex
DO you think it will be able to be mounted for things like track days etc? Would those speeds risk the camera falling off the outside of the car? This sounds like we are in for some awesome footage on upcoming events!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
