hey guys
looking at a car in qld... its stock so no mods... complianced and rego over there...
want to buy it and bring it back here... however so many myths go on about transferring it into SA rego and into my name... trips to regency blah blah
can anyone give a straight deffinate answer?
I did this 18 months ago. (Qld to SA)
Just take it down to Sturt St? Inspection station for a Vin check, then drop the papers and Qld plates off at your local motor reg office and collect your new plates and a rego sticker.
Sturt St Inspection station are much better than regency, just make sure obvious defects are removed (tyres etc) but if its stock you shouldnt have too many problems there.
It depends where you live. I tried to do the sturt st inspection as everyone said it was easier to get through there, but they told me due to where i live it had to go to regency park. This is no biggy tho! it doesnt go to the "pits" for a simple state rego change. They have a new warehouse building you just roll your car through, they do engine number and VIN checks to make sure nothings stolen and everything checks out. Obviously you cant roll through there with a big highmount, but if the car is stock you will have no problems whatsoever.
I took my perth registered GTR through there with Z32 AFM's, HKS turbo's, and Power FC. All i did was bolt a stock exhaust on and it was stock height. They checked the numbers, had a quick look at the tyres and that was it. All they looked at inside was the odometer. None of this kickpanel off business you get through the pits.
You'll have no problems at all, the whole process took maybe an hour, most of which was waiting for my turn, then you take the papers they give you to the office next to the pits and get your new plates. The car inspection took all of 5 minutes, then another 5mins as he went to run the numbers.
the other way to do it, is if you can get it regoed in your name in qld (use a relatives address etc) then all you have to do is take your qld rego papers with your name in to transport office anywhere and they transfer it straight over, thats how i got my car done when i moved here, because it was already regoed in my name and still had current rego they just transfer it across didnt even need to see the car. But since yours has no mods then i wouldnt worry bout it...
Edited by sinistagtst
Just did it yesterday myself. All you do is go into the transport office, fill in the paper work and bam, that's it. That is providing the car is in your name so you don't have to go over the pits or anything >_<
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
