Just got the rb20 a new crank, main and big end bearings. The crank was measured at an engine shop, and the correct grade bearings were then installed going by the crank size.
Just put the engine back in, and the motor is so tight it cannot be turned by hand or the starter motor.
What do i do now? should i tow it?
You should not try any further to turn the motor over, by whatever means - you'll only do damage. It will be a case of unbolting the crank and doing it by the numbers......measure all the bearing clearances using something like plasti-gauge. Well, thats what I'd do. Measuring the bearing clearances directly is the only way to be sure, AFAIC.
Another possibility is that you have a 'tight' thrust face, have you measured the end float on the crank ??
If you can't turn by hand, theres something wrong.
Didn't you or they try turning the crank before installed into the car?
Might also wanna check the valve timing.
i am quite confident that the bearings are the correct size, crank was measured to see if it was out of round etc, and the plasti-guage was used. there was bugger all end float, but it wasnt measured.........
also, forgot to mention, i had it running for a minute or two, then it stalled and now its siezed. but it was very tight before also. VALVE timing also checked.
Edited by HRthirtyone
Dude... take it apart, and double check everything. If you try anything dodgy to save yourself ripping it out and opening it up, your jsut gonna break something cost yourself mroe money and be back at square 1.
Unfortunately its the only way to be sure in a case like this.
when it started the first time how much oil pressure did it have ?
ANY ?
Ummm, some pretty important details. Sounds like some clearances were not correct and that, possibly combined with low or no start-up oil pressure has caused a bearing or bearings to pick-up. I really don't think you've got any choice but to at least drop the sump and check the crank and bearings. Should be no nead to remove the head. Of course all this assumes that something really unuasual hasn't occured (eg seized starter....extremely unlikely).
didnt check the oil pressure when it started, because i started it outside the car, and it was running rough, i just checked all the injector plugs and coil pack plugs, then it came good, idled on all six for about 30 sec. then stalled. Oh, plenty of assembly lube, and it has a new starter motor that is all good
the ONLY thing you need to worry about when first starting a fresh rebuild is oil pressure.
when you have the engine on a engine stand, and before you bolt the sump on, pour some oil into the pickup "with the motor upside down" and get a friend to slowly turn the crank around so the oil pump can
a: prime itself
b: pump oil to the crank and other essential areas that oil is required.
it only takes a couple of minutes but you will never have any oil pressure issues on first startup.
I hate to say it but its spanner time for you.
any sort of death noises b4 it stalled? when rebuilding its important to get ALL measurements cheaked, then as ur instaling pistons once measured, turn the motor over by hand afta each piston is installed, thus making sure that its not excesivly tight, e.g poor thrust face or end cap clearences
Mine with the plugs in was pretty difficult to spin over by hand.. But you could feel it was free until one of the pistons came up on its compression stroke.
The RB20 that came out all though it still had ~145psi in all cylinders was very very free even on its compression stroke.
A little sideways on the topic but is there an engine building thread that has all the obvious things to check in it like:
Bearing clearance's and end float clearances
All bolt torque specs and torque orders for the main and head bolts
Tricks for pre-oiling
Startup check lists and cam/lifter wear-in procedure
Assembly tricks like vasoline in the oil pump
Just an idea, but it would make a good sticky thread for those that build engines but would like all the data available on the one page.
Cheers,
Ian
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
