Just got the rb20 a new crank, main and big end bearings. The crank was measured at an engine shop, and the correct grade bearings were then installed going by the crank size.
Just put the engine back in, and the motor is so tight it cannot be turned by hand or the starter motor.
What do i do now? should i tow it?
You should not try any further to turn the motor over, by whatever means - you'll only do damage. It will be a case of unbolting the crank and doing it by the numbers......measure all the bearing clearances using something like plasti-gauge. Well, thats what I'd do. Measuring the bearing clearances directly is the only way to be sure, AFAIC.
Another possibility is that you have a 'tight' thrust face, have you measured the end float on the crank ??
If you can't turn by hand, theres something wrong.
Didn't you or they try turning the crank before installed into the car?
Might also wanna check the valve timing.
i am quite confident that the bearings are the correct size, crank was measured to see if it was out of round etc, and the plasti-guage was used. there was bugger all end float, but it wasnt measured.........
also, forgot to mention, i had it running for a minute or two, then it stalled and now its siezed. but it was very tight before also. VALVE timing also checked.
Edited by HRthirtyone
Dude... take it apart, and double check everything. If you try anything dodgy to save yourself ripping it out and opening it up, your jsut gonna break something cost yourself mroe money and be back at square 1.
Unfortunately its the only way to be sure in a case like this.
when it started the first time how much oil pressure did it have ?
ANY ?
Ummm, some pretty important details. Sounds like some clearances were not correct and that, possibly combined with low or no start-up oil pressure has caused a bearing or bearings to pick-up. I really don't think you've got any choice but to at least drop the sump and check the crank and bearings. Should be no nead to remove the head. Of course all this assumes that something really unuasual hasn't occured (eg seized starter....extremely unlikely).
didnt check the oil pressure when it started, because i started it outside the car, and it was running rough, i just checked all the injector plugs and coil pack plugs, then it came good, idled on all six for about 30 sec. then stalled. Oh, plenty of assembly lube, and it has a new starter motor that is all good
the ONLY thing you need to worry about when first starting a fresh rebuild is oil pressure.
when you have the engine on a engine stand, and before you bolt the sump on, pour some oil into the pickup "with the motor upside down" and get a friend to slowly turn the crank around so the oil pump can
a: prime itself
b: pump oil to the crank and other essential areas that oil is required.
it only takes a couple of minutes but you will never have any oil pressure issues on first startup.
I hate to say it but its spanner time for you.
any sort of death noises b4 it stalled? when rebuilding its important to get ALL measurements cheaked, then as ur instaling pistons once measured, turn the motor over by hand afta each piston is installed, thus making sure that its not excesivly tight, e.g poor thrust face or end cap clearences
Mine with the plugs in was pretty difficult to spin over by hand.. But you could feel it was free until one of the pistons came up on its compression stroke.
The RB20 that came out all though it still had ~145psi in all cylinders was very very free even on its compression stroke.
A little sideways on the topic but is there an engine building thread that has all the obvious things to check in it like:
Bearing clearance's and end float clearances
All bolt torque specs and torque orders for the main and head bolts
Tricks for pre-oiling
Startup check lists and cam/lifter wear-in procedure
Assembly tricks like vasoline in the oil pump
Just an idea, but it would make a good sticky thread for those that build engines but would like all the data available on the one page.
Cheers,
Ian
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
