Which R33 GTS-T would you get?
35 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Okay here's the problem: I have shortlisted 2 R33 GTS-25Ts, 1 sedan, 1 coupe, and both have auto transmissions.
Car #1 (sedan)
Faults:
1) Rear seat belts clips are facing the wrong direction. Seat belts look too new for 5 year old.
2) Air con vents don't close fully.
3) Left side mirror doesn't fold in.
4) HICAS diagnostics show an error code of #21: Vehicle Speed Sensor not present. (Could it be because the speed limiter on the ECU was removed?)
5) Alarm doesn't work sometimes.
6) Car steering wheel pulls to the left even on a straight road. But, it doesn't vibrate even at 100km/h.
Note: The log books are missing! All minor maintenance such as oil changes are supposedly done by the owner himself. Major servicing such as replacement of timing belt done at a non-nissan service centre.
Car modifications:
Nismo speedometer, Turbo Timer, D2 adjustable suspension, Spitfire coils, exhause changed from turbo-back, ECU changed and car tuned on a dyno.
Edit: Dyno results here:
Auto sedan going for 12k (or 11.5k w/o the D2 suspensions).
Car #2 (coupe)
Faults:
1) Left side mirror doesn't fold in.
2) Air con not working (apparently, it needs gas).
3) Small dent and scratch on left side of car.
4) Boot doesn't open with the key.
5) Right front speaker not working.
6) A bit of black smoke present when revving engine at neutral.
7) Spare tyre area might have been repaired.
8) Transmission slips a bit.
9) No alarm system at all.
10) Not really a fault, but there's no turbo timer installed.
Car modifications: Apparently, it hasn't been modified before and everything is stock.
Going for 11.5k.
I can tell that Car #1 is better maintained then #2. Which one would you get, and why?
I'm torn between these two options... what would it cost to repair them? :(
Edited by shoebox
https://www.sau.com.au/forums/topic/136783-which-r33-gts-t-would-you-get/
None keep looking.
If you are looking for a Skyline with log books, fat chance. These are 10+yr old imported cars, most don't come with log books from Japan to begin with.
Sounds like you may be a novice at this, may be a good idea to take a car, you are interested in buying, to a good mechanic to check it over for you.
id pick 1 because the gearbox doesnt slip, $500 is nothing really since you said the gearbox slips in the other. i have a nice manual 4 door you can buy off me for 16.9k, its immaculate s2 wif 85000klm :( (shameless plug)
Edited by toffy
Yea, i'm new to this (it's my first car actually!), and i'm intending to take car #1 it to a mechanic maybe next week.
I can understand why #2's bad, but why not #1? I don't think the repairs will be expensive, will it?
By the way, dyno graph for car #1 is below.
I was *this* close to buying car #1 until i came here.. ^_^"
Edited by shoebox
I dont think #1 sounds that bad... that power rating seems ok considering the mods so sounds like a healthy engine, dont write it off yet get it checked out by a mechanic.
Only problem is the idea of an auto, dont wanna buy one then regret it later on..
Car #1 (sedan)
Faults:
These two points are pretty major. One may think number 6 could only be an alignment, but it could also be the HICAS playing up. Causing the rear end to be "floaty" and majorly diminishing the handling. R33's are in abundance, why bother buying someone elses problems when you can find a clearner example for the same price :angry:.
there's no such thing as "cheap" and "good" :)
I vote for keep looking, and keep saving. 12k won't get you a good 33, you'll end up having issues with it and spend more in maintaining the thing I guarantee.
Don't worry about log books, use careful judgement to evaluate whether the cars appear to have been looked after. Neither of those cars excite me at all, but then I was more interested in spending up to $20k on a mint example (and loving it :D). My car didn't have log books but a careful inspection by me and a 5 page report by State Roads pretty much guaranteed it had nothing to hide.
I agree, keep looking.
I looked around for months before I found mine. If you're not sure, then its probably not the right one. When I saw mine, it was perfect. Looked like a brand new car (both the engine and interior)
Thats what you're looking for.
Keep in mind, some repairs can be more costly than you expect. I looked at one that only needed its front bumper repaired. Got a panel beater friend to have a look, and he told me that with the brackets that were missing and the work that needed doing, it would cost over $1000. Too much for just a front bumper.
I paid nearly 18 grand for my car back in April and so far nothing major has gone wrong (only needed to replace bushes that cost 70 or so bucks after a few months). The car has now done tad over 53,000 Kms and Im very happy with it!
I did nearly make the mistake of paying around 15 K for a car that had an oil leak and a faulty seat.
Keep looking and dont be afraid of paying extra if the car is perfect.
Edited by Sir-D
there's no such thing as "cheap" and "good" :wave:
I disagree - i picked up mine for 11k and apart from a dirty aac valve the car is spotless
There are heaps and heaps on carsales around 12-14k which have been on there for a good 6 months - a lot of owners are getting quite desperate to sell
Hmm~ yea, i agree that both cars aren't exactly very good...
I'm sending the sedan for an inspection at a workshop though. Hopefully nothing big comes up, but I'm not very optimistic about the HICAS.
I've just found a 13.5k auto coupe which the owner says is in excellent condition (don't they all!)... maybe I'll take a look at that one ^_^
I looked around for months before I found mine. If you're not sure, then its probably not the right one. When I saw mine, it was perfect. Looked like a brand new car (both the engine and exterior/interior)
thats exactly what i did :rant: , mine is the tidiest gtst in my state imo :P .... i must admit theyre hard to sell though, at 16.9 k i dont think mine is dear for a s2 that IS faultless :rant: i havent even had 1 person look at it yet though :rant: .... not even a phone call :P
Wow, that is quite steep actually (at least to me). What year is it, and where're you located? Any mods?
lol,you get what you pay for :). too far away for you to look at mate, its in taz. its got a few mods, 18in wheels , factory manual 4d, 96 or 97... avatar pic<<
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
