Hi,
When should you use a turbo timer?
I have a turbo timer installed (standard car running standard boost) and i only use it when i give the car a bit of a thrashing. Normal driving i dont bother with turbo timer.
is this wise? or should i always use it?
cheers
https://www.sau.com.au/forums/topic/136806-turbo-timer/
you only need to use it when you've been on boost just before you're turning the car off.
If you drive normally and stay off boost when you're getting close to where you're going, you dont need to use the TT as the turbo hasn't been doing anything
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2543148
TTs are after-market gadgets. If Nissan had wanted you to use one, they would have installed them as standard items.
TTs are generally for idiots who can't control their right foot during the last km of any trip, and are then too impatient to wait with the car for a minute while the turbo cools down a bit.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2543233
I dont have a TT...
...I just take it easy as im approaching my destination, and usually wait about 15-20 odd seconds (Usually spent closing windows, sunroof, side mirrors) before switching it off....but i never let it sitting idle as you'll end up trapping a bit more heat due to no/less airflow.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544698
exactly. letting it sit on the spot idling creates heat soak, which can raise the temp. if i fan it around close to home i usually just idle around the block to let it cool down.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544858
I dont have a TT...
Ha? Can you elaborate? I live near a big hill and when I climb it my car usually sits around 2000-2500 RPM. So the turbo is working slightly and needs bit of cooling (20-50 secs) so I just idel in my drive way If i have time or walk off with TT on.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544949
I dont think anyone is saying a TT is harmfull champ!
Sir-D,
Im not sure what you want me to elaborate on? ...basically all im saying in my post is to take it easy as u approach ur destination and you wont really need a turbo timer.
And my personal opinion is that if you think a TT is gonna save ya then think again.
Thrashing your car then coming to a complete stop and leaving it on TT will NOT cool down the rest of your car like transmission etc...
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2544976
TTs are a bit of a wank, all that's needed is some common sense either drive gently and give it 10 seconds to idle before turning off or let it idle for 30-60 seconds and be done with it. Did this with my last car and never had a problem.
I do have a TT integrated with the alarm on my current car, this lets me be lazy and take the key out, get my stuff etc and then as I walk away I override the TT and turn the motor off then arm the alarm. Could count the number of times I've let it run the full 90 seconds (fixed) on one hand.
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2545093
Sir-D,
But isnt that related to any car, turbo or not as far as cooling the tranny etc goes?
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2545444
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to run down in speed and cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed.
http://en.wikipedia.org/wiki/Turbo_timer
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2549478
Ive seen on some TT's it says suitable for Turbo charged Vehicles and NA vehicles. I always go easy a few mins before reaching destination and give it a few secs when i pull up.
The shafts on most turbochargers spin in excess of 50,000 RPM and generate lots of heat. To keep your turbocharger's heat under control, most are cooled by circulating oil or water (coolant) around the shaft. The turbocharger's shaft is free to rotate at will and there is no way to stop the shaft from spinning after shutting the engine off. To dissipate and stabilze the heat in the turbocharger, most manufacturers recommend that a car be idled for a period of time after moderate to hard driving to allow the oil/water to take heat out of the turbocharger.
Failure to reduce the temperature of the turbo could result in the oil around the shaft "coking". Coking is basically the baking of oil, turning it into a hard substance that could plug your oil lines and cause oil "starvation", preventing proper cooling of your turbocharger and reducing it's operating lifespan.
Edited by 95SKY
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2549516
If you take it easy just before you reach your destination.. a turbo timer isnt needed..
anyone who thinks they can drive hard then shut off their car immediately is stupid.. turbo timer or not
https://www.sau.com.au/forums/topic/136806-turbo-timer/#findComment-2549844
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
