I have one of them funky dr drift chips. I dont have that many mods but he always seemed quite confident that if I ever did go to town on it he could retune it to suit.
Attached dyno sheet. Notice the afrs, and the general smoothness of the curve.
Edited by dangerous_daveo
A/F ratios are probly the biggest advantage of a Dr Drift chip. I want to get a before and after sheet coz mine are so farked its not funny.
Edited by konect
There are many advantages for using a chipped standard ECU over a complete aftermarket ECU. For starters, you already have the expensive pieces of hardware; the wiring loom and engine management system itself. They may not have the real-time tuning functionality of an aftermarket item; however for the fraction of the price you really cannot beat them.
I have used Sam (Dr. Drift) several times and have to say I am nothing but impressed.
Not to mention, the great advantages of factory style cold start, idle, a/c, etc.
This is good if your ecu is able to be chipped, but the amount of tunners are highly limited. (ie: Sam is going interstate to tune customer's ecu's)
This limited amount of tunners, may lead to higher prices per tune, not sure though, so please no flaming :D.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
