  • Replies 50
I'd be interested in a touch-screen LCD for $240... pending some pics and resolution/technical spec's!
ME 2!!!!! man that looks SHMICK!
like sorry for the noob question:
i dont no any thingt about the ECUTALK software.. so how does it work.... you keep a laptop in the car and are you just running the software from the laptop and av / outing to the screen....
and like so obviously it comes with some sort of unit to wire to all the sensors which plugs into the pc by usb or something...
i am VERY interested in doing this just need the basics answered....haha (now where can i put my headunit if i get one)
Yeah, the laptop is hooked via the serial port to a 'consult' device which interfaces with the car. I got the consult device through a group buy via 'Newkleer'. The LCD has a VGA input which connects to the laptop.
I'll post some pics up shortly to show how I set the whole thing up.
cool can you give me a link to the thread? i have seen the ecutalk lcd sreens by newkleer so thats it and you just put that under the seat to? or you just dont have to buy the lcd screen just the unit with all the sensors which goes into the pc?
yeh info would b nice haha cheers! looks mad
I'm not sure if newkleer is still making thee units - they were different to the LCD unit he has now - best to PM him and find out. Otherwise try these guys http://www.plmsdevelopments.com/consult_if.shtml
Here are some more pics of the install:
post-4014-1164003067.jpgpost-4014-1164003102.jpg RoadRunner frontend for music/video/gps, etc
post-4014-1164003154.jpg post-4014-1164003265.jpg mounted the LCD to a mounting bracket I had from an old GPS unit
post-4014-1164003197.jpg laptop under the seat with consult interface etc.
You can build a fast and reliable computer for this Monitor to function in a car by purchasing a PC box that can be mounted in the boot or under a seat. Micro-atx motherboard, additional external sound card, with a 1gig or 2gigs of ram and a AMD 64 dual core system with a nice budget 3d card should do wonders to get video, audio and the processing speed for your data.
You can get computer boxes totally purpose built for incar use and have a PSU already made for direct connection to your batt.
Edited by SAZilla
Pauly, if you slam a dual core amd into a car your power draw will be something in the range of 400watts, you'll need something in the order of a 300-400watt DC-DC power supply to give it enough juice, and you'll probably flatten your battery if you're not careful. This is the reason why EPIA mainboards or mini-itx are so popular among carpc enthuasiasts.
u dont need the lcd display i make, though it does come with a consult interface (but u cant have both it and consult interface working at same time - have to flick a switch between em). plmsdevelopments.com or blazt.biz will get you a standalone interface for ~110 or so (if u go with plms, ask them price without datascan software, as u can use ecutalk for free).
i might get another batch of consult interfaces done at some stage, but nothing definite (i could probably get assembled ones made for ~70$)
ceedub - try using 12 rather than 16 gauges, will use screen better i think
Edited by NewKleer
I was thinking something in the order of 250 watts max howie, you dont need all that much power to run a computer with an average 3d card... when you start seeing GT or X(insert number here) in 3d cards thats when power draw is higher. a nice 6600 PCI-e will do the job nicely and if you put a conroe instead of a AMD 64 dual in the comp itll run even lower wattage. Conroes (Core 2 Duo) are great on power saving (based on laptop tech).
250 probably wouldn't cut it. There's a power specification chart on mp3car.com which explains why you'd probably brown out at 250 dc.
I know for sure my single core 3500 at home wouldn't boot on 250watts, imagine 250watts in a dc-dc psu.
Edited by Howie
will organise group buy once I have 10 people:
So far registered interest from
1. Howie
2. travb81
3. steveo r33
4. jaypee 23
5. nozila
6. hydie
7.
8.
9.
10.
Once I got 10 I will reconfirm price and work out next steps.
I need 4 more people interested in a Lliliput screen to organise this group buy.
1. Howie
2. travb81
3. steveo r33
4. jaypee 23
5. nozila
6. hydie
7.
8.
9.
10.
ceedub,
do you have a dvd/cd drive hooked up to your carputer?
I'm wondering how to mount a dvd drive and this LCD touch screen. Seen some units on mp3car.com which combine the two into a single DIN or a double DIN unit, they seem like a good idea.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
