Good timing! I just ordered some.
Thule brand racks through Roof Carrier Systems here in Melb.
$295 for racks - $135 for extender kit to take my bike carrier.
Getting them fitted on Saturday - will take photos :)
I have towbar on my R33GTS25T, I had it custom made by Carasel at Moorebank. It was about $350 fitted and wired.
I pulled a car trailer to and from Melbourne without problems (1400kgs on way back) even though the bar is rated at 1000kgs.
I do have a slight contact between one exhaust bracket on LHS of muffler but have had time to have it reshaped. My taillightparkers no longer work on the combination switch but work from foglight switch, I suspect the additional load from the trailer lights may have fried the combination switch so relays may be need if you want to tow rather than carry a bike.
are you able to take the tow ball part off? i wouldn't want it there all the time...
have you got any pics?
  • 2 months later...
They look like they'd hurt the car :D
I was thinking about getting some for the trip down to the snows next month, but by the looks of those clamps, they aren't going anywhere NEAR my car...
OK - just under 3 months and I get my car back :D Yay!
Here are promised photos of Thule racks:
Just been to IKEA
Couldn't be bothered removing the bike carriers before loading up with a new desk and coffee table :)
Pads on roof are soft rubber, clamping arms are plastic-coated.
Racks and bike carriers all made by Thule.
Don't know what the hell is going on with my posts - but anyway...
Merli: The clamps are very soft plastic and grip onto the rubber part of the window surround. The pads are all rubber - their impact on the car was a MAJOR concern for me - but they are fine.
I need the car to be practical, so had to get something - but these are much softer and car-friendly than I thought :D
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
