My skyline has a gt3540rbb, injectors, plenum, power fc etc its kinda laggy in the lower revs so i was thinkin to install a wet nitros kit so it will pic up quicker on the lower revs and i just want to know if it would it be a good idea, has anyone tried it? anyway let me know wat you guys think.
https://www.sau.com.au/forums/topic/136903-want-an-opinion-on-nitros/
definately. whether or not ur internals are standard just use a 50 shot. it will get the boost up nice and quick. use the nitrous for this reason not so much a hp gainer.
Its not street legal.
Like other people, I'm wondering about x_pac's application. Nitrous doesn't last too long, so you either need big bottles or to use it sparingly.
If your car only lives life a quarter mile at a time its not an issue, but if you're planning on using N2O every time you take off from a set of lights its not the best option.
yea the plan is to just use it for 1/4mile not of every single traffic light. does anyone know how many 1/4 miles a 50 shot nos tank can do?
sigh...
how big of a bottle?
i mean, how long is a piece of string
What do u think? A street is designed for cars to get from A to B not designed to fly from A to B.
If that is the case, then we have no need for 300+rwkw cars either, but they are still legal.
Ahh well, least this is the first time someone on SAU has attempted to patronise me.
Just because a car has more power than it needs to get up to the speed limit, doesn't mean that the owners have to drive it like they stole it.
There are plenty of high powered cars on the road, most of which are driven sensibly.
Something as unpredictable as N2O isn't safe/suitable for road use in any situation.
While I dont see the need to use Nitrous on the street, the above statement is completely untrue. Nitrous is neither unsafe nor unpredictable. It is however, illegal to use on public streets.
Adrian
If it was safe, there would be no reason for it to be illegal.
If someone is too tight/stupid to take it to a track, where else are they going to play with it?
I know I certainly don't want to have some idiot playing with nitrous while they're driving next to me.
...especially if it's the first time they've played with it, simply because they won't know what to expect from it.
I don't for an instant believe that anyone who is silly enough to use it on the street would have the ability to do so in a 'safe' manner.
Add into the equation fun things like nitrous backfires, DIY installations, and who could forget the genius who connected his bottle heater to a constant 12v and went off and forgot about it? Not much different to leaving a car sitting in the hot Australian sun.
Anyhoo, with the mods listed above, I didn't see x_pac28 mention which fuel pump was being used?
Formula to figure out usage:
0.8 lbs N2O X 10 seconds = 100HP
eg: If the system is jetted for 100HP it will use 0.8 lbs of nitrous for every 10 seconds of usage.
...and a reminder of why this is not a toy. :P
You will get 8 0r 9 passes on a fifty with a 10lb bottle. you pay about $110 a fill.. bit expensive to go blasting around on the street with. but will definately give you the midrange you are after. have a customer car similar to yours, ran 11.75 @121mph on 21psi. Put 75 bottle on it and it ran 11.66 @123mph on 15psi with 4 deg total timing out.
Edited by BezerkR32
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
