G'day RS,
I'm pretty sure that the grille in the pic is a GTR look-a-like grille.
You can get them for around the $100 mark I think. But just make sure you get one that suits your car cause I've read that they are different for the series 1's and series 2's.
Cheers
J
https://www.sau.com.au/forums/topic/13692-r33-front-grille/#findComment-269582
Yepp, the 1993 to 1995's are the same.
Mines a Sept 1995 car and the bonnet is the same as a March 1993.
I think the series 2's have a slightly lower bonnet lip in between the lights. Or maybe it's slightly higher......??? But they aren't the same :(
J
https://www.sau.com.au/forums/topic/13692-r33-front-grille/#findComment-269592
Originally posted by rs73
reckon that grill with red "S" badge will look good on a winered gts-t, or just get a hollow grill (without the "S" badge)
Hmmm, doesn't look too bad. I've seen the open ones and they are nice too, but just a little bear for me.
I think the 'S' would go nice.
J
https://www.sau.com.au/forums/topic/13692-r33-front-grille/#findComment-270486
the very rare i been trying to find one in sydney i think they are the full m-spec front grill and the other type is the type m they look nice ive seen them mostly on silver 95 skylines goodluck and if ya find one can ya let me know were when and how much?
https://www.sau.com.au/forums/topic/13692-r33-front-grille/#findComment-270871
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
