Hello,
Im a bit of a learner when it comes to turbos.
Now i've had my r32 gts-t for about 10months, the previous owner in japan has fitted a z32 AFM, adjustable fuel pressure regulator, the injectors im fairly sure are GT-R ones as there is a resistor pack, and they only read about 3 ohams. The ecu looks stock, but, things like the speed limitor have been removed, so i assume its been played with also. The car also has a FMIC
Now, Im not quite sure how high i should turn the boost up, at the moment im running it fairly stock, as im frightened of turbo damage if i turn it up to much. Today i removed the dump pipe to have a look at the wheel, now, i don't have a clue what i was looking at so i took a picture in the hope that someone on here would be able to tell me if its ceramic or steel. The acual wheel is not all that big so i'm assuming its pretty much the stock unit.....
Sorry about the poor image quality.
Thanks
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/
whiter31gxe,
Have you had it on the dyno for a power run to see if its pinging and what the afr's are like?
Do hit the dyno before winding up boost or possibly wind the boost up on the dyno. At least you can see what its doing. Especially as the ecu has clearly been fiddled with.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544390
Thanks for the replys.
I have not had it on a dyno yet. I forgot the mention that i do have a SAFC II hocked up to the system, still have not had it tuned yet, been holding out till I work out what i was going to do turbo wise, but, it does not register any knocking.
Also does anyone have a recommendation for a dyno to use on the mid north coast?
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544699
which also has a ceramic wheel?
yes, but you can run around 14psi comfortably on the RB20 with 25 turbo.
ITs been well covered the gains from putting an RB25 turbo on
http://www.skylinesaustralia.com/forums/in...howtopic=103095
http://www.skylinesaustralia.com/forums/in...showtopic=66556
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544713
Hello,
Thanks
dude,
that doesn't look like the standard rb20 turbo.
if you look closely it actually looks like the 9-blade turbine which is found in the HKS 2530.
you might want to check the id-plate on the centre core.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2544779
As people have said:
1) Get on a dyno to check the AFRs. That exhaust wheel looks pretty good to my eyes (in terms of colour) but if you fiddle the boost that can change so don't change the boost unless you're on the dyno.
2) RB25 turbo is a good upgrade on an RB20, I went with the S2 turbo on my last car and the power delivery was fine. But check the turbo you've got on there as it sounds like you could have an aftermarket one already :D
3) RB25 turbos - S1 has a steel compressor wheel and ceramic turbine wheel. S2 has a nylon compressor wheel and a ceramic turbine wheel. The R34 turbos have a plastic (!!!) compressor wheel and ceramic turbine wheel. I picked an R33 S2 turbo as nylon is lighter than steel so should spool a bit better on an RB20.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2545058
dude,
The RB20 turbo that came off mine has 9 blades. Looks identical to mine.
The R33 S2 and R34 Compressor wheels are made of the same plastic type material. Its not plastic just looks like black plastic. :D
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2545077
2) RB25 turbo is a good upgrade on an RB20, I went with the S2 turbo on my last car and the power delivery was fine. But check the turbo you've got on there as it sounds like you could have an aftermarket one already :(
why so "!!!" over plastic compressor wheels? - nylon is a polymer also - kevlar is a polymer and its stronger than steel and used as bullet proofing - "plastics" dont all necessarily have the same properties of a shopping bag.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2545339
i already knew about the "r33 turbo on an rb20 running 14psi is fine" thing, but for my knowledge, why is an r33 turbo able to run 14psi on an RB20 but only really good for a daily 10psi on an rb25?
is it the extra displacement has a lot more heat, which causes the wheel failure?
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2546401
Airflow... The RB25 head flows air in and out of the pots easier.
14psi on an rb20 makes ~190rwkw, ~11psi on an rb25 makes ~190rwkw. They will both be spinning at a similiar RPM and pushing similiar air. Once you start pushing a turbo past its airflow capability it begins to push hotter and hotter air that is more prone to detonation, higher egt's (the real killer), greater turbine back pressure etc.
No one apart from garrett and the likes really knows but thats basically it.
https://www.sau.com.au/forums/topic/136920-exhaust-turbine/#findComment-2546492
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
