post-11094-1159706016.jpgpost-11094-1159704951.jpgpost-11094-1159705828.jpgpost-11094-1159704923.jpgpost-11094-1159704889.jpgSelling my beloved Series 1, it's had a few mods done. Project that never really got finished, so the car doesn't need much to get it really going hard
Nissan Skyline R33 GTST
Manual
Hi-Flowed Turbo by JPC in Thomastown
Lowered on RSR springs all round
102,000 kms
Excedy Heavy duty clutch
3" turbo back exhaust with HKS muffler
600x300x75 FMIC
19 inch rims with 70-80% tread
Pager Alarm with immoboliser
K&N pod filter in stainless steel cold air box
Strut brace for rear
Service done every 5,000 kms
Pivot turbo timer, looks very standard
Sound system including DVD player and screen
Electronic rust protecter wired into car
Extra parts to go with car:
16 inch rims
Stock exhaust
Fuel cut defender
Greddy Profec A
many more
Can't really think of anything else, just need it to be sold.
This car is my passion but as most of us would know i'm in for some interesting times.
Asking for $16990 ONO
Pm me or call me on 0402428854, P.S. i don't really like private numbers
i'm in melbourne
Edited by improvin
https://www.sau.com.au/forums/topic/136923-14500-cheap-with-modsselling-asap/
hey sorry guys i can't swap it for another car, fiance already has a normal/friendly car; So its up to me to make the "sacrific" thanks anyway.
Need to really sell it as soon as possible, open to any other reasonable offers...thanks once again.
Guys
This car is the best series 1 R33 I have seen. Subtle mods, yet still manages to grab your attention.
I know Anthony Personally and I have never seen that car with a spec of dust on it. I waited 3 months to sell my skyline and it was immaculate, you just have to wait for the right person to come along.
I assure you guys, the first serious person that goes and has a look at this car will buy it, you CANNOT fault it. He is after a Motorbike and I know that he wouldnt sell it for another car!
After being a owner of a R33, I must say, they have a classic look and bulletproof reliability- this ones had all of your usual Mods done so no more to spend, sometimes we forget that stock ones are going for like 1k cheaper, but you would have to spend 6k+ to just get it to the same level of mods as this one.
Good Luck with the sale man I know itll be sold soon.
Guys thanks heaps for the support!!!! i thought this was pretty cheap for a car with a couple of "not bad" mods......but not any real serious buys though.
I need to sell the car asap serious offers considered.
thanks again guys
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
