Saturday Cruise 7th October
Yes, an R34 workshop manual is downloadable. The R32 GTR one which is findable everywhere would also do the job, seeing as almost all those bolts are same-same enough.
It can be hit and miss, I can fit 15mm ones on the v37, but only because the wheel happens to have voids on the mounting face that allow it to fit. Have you checked the mounting face of the wheel and know it will not sit flush? Rather than cut (or try and find shorter) studs, just buy a thicker spacer (unless clearance from the wheel to the guard does not allow it), then everything is reversible in future
Obviously you need shorter studs (don't just cut the original studs off!) and really short nuts that will fit in the spacer. Thus exposing the problems with thinner bolt on spacers.
https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062>ssaleid=SSE-AD-18219062&pageSource=details
By drifter17a · Posted
does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
