Im after some injectors for my 33gtst. i need something bigger than 550cc. i have a set of 6 s15 480cc injectors, if anyone is interested in a swap with cash adjustment. even if someone has some s6 rx7 secondary injectors as i have 2 sitting at home already. please pm me if you can help me out.
cheers dan
Edited by sinistagtst
https://www.sau.com.au/forums/topic/136960-injectors-for-rb25det/
Hi sinistagtst, the 480cc S15 injectors you have.. are they direct fit? with the plug etc etc. Also how is the condition of them? I'm actually looking for injectors at the moment.. anything above what i have now is great. How much you willing to sell them for?
hey mate,
yes they fit straight into your fuel rail and yes they plug in no worries at all. there in good nic when i bought them they had done 30000kms (so the buyer said) and i havent used them at all (i put a put a new turbo on and discovered that my engine was blown aswell). i would sell them for $420. if you want them i wont be able to get them off my car till next weekend. pm me if your interested.
cheers dan
Hi mate,
I've got a set of 700cc for sale at the moment. $500 and they're yours.
Cheers
hey mate,
cheers dan
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
