is this a good deal?
6 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I am looking to buy a new (well used) car and my friends have requested that these cars are pretty good/fast, and its within my $14000 budget, what do you guys think? It is a good car/deal?
http://www.carpoint.com.au/used-car/NISSAN...ia/2035093.aspx
I do currently have a 1994 Holden Commordore VR, had it for 5 years - looking for to sell it (when I purchase the new car) and drive something new.
If you dont think its a good deal, recommmend me any good car around the $14000 mark
Edited by sumguy
https://www.sau.com.au/forums/topic/136990-is-this-a-good-deal/
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
