Spiderman Posted July 5, 2002 Share Posted July 5, 2002 I have been mucking around with the BOV and now it sounds like ****!. Im not sure on wether to tighten it or loosen it, If its to tight then it wont release the boost until its too high and too loose it will lose preasure. It used to sounds really good but now it sounds crap now, wish i never touched it but curiosity got the best me. Any ideas please how to get it hissing pssssstttt nicely once again thanks Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/ Share on other sites More sharing options...
UNREAL Posted July 5, 2002 Share Posted July 5, 2002 What brand of valve is it? Does the car stall on gear changes? Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-27384 Share on other sites More sharing options...
Guest | hype^ | Posted July 8, 2002 Share Posted July 8, 2002 on a sorta related note.. my car stalls when i brake with the clutch in after boosting.. is this coz the bov is too loose?? if so how do u tighten a blitz bov??:confused: (yay my 100th post!! ) Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-28254 Share on other sites More sharing options...
Spiderman Posted July 9, 2002 Author Share Posted July 9, 2002 Unreal, Its a Blitz, i also have had my car stall like HYPE has Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-28633 Share on other sites More sharing options...
Guest | hype^ | Posted July 9, 2002 Share Posted July 9, 2002 common ...some 1 who know red this please! Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-28975 Share on other sites More sharing options...
Spiderman Posted July 9, 2002 Author Share Posted July 9, 2002 Last night comnig home from work, I couldnt stand it anymore so i pulled the BOV off and pulled it all apart. It was really dirty so i cleaned it all up oiled it and put it back and noticed that the pipe that runs from the BOV to the Bleed valve was torn where it connects to the BOV so i cut it and put back on. !!!!!!AND IT WORKS!!!!!!!! :lol: The problem seems to have been the torn pipe but after the cleaning and oiling of the BOV it sounds better. Have to see if it stalls now, hopefully not Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29239 Share on other sites More sharing options...
AndyMac Posted July 9, 2002 Share Posted July 9, 2002 Its a very common problem with Atmo B.O.V's When the inducted air is taken in the Air Flow Meter reads the amount and adjusts the fuel delivery to suit that amount of air. The BOV releases the same air that the air flow meter "thinks" has been mixed with the fuel. So basically the computer injects the fuel but the air has vented out of the BOV, which causes the engine to "run rich". When the mix isn't right and its too rich the engine stalls. Like the factory unit, a "plumb-back BOV" recirculates the air back into the system, thus equalizing the air/fuel ratios again. Apart from the sound there is no clear advantge that i know about from having a Atmo BOV. Probably disadvantge. Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29247 Share on other sites More sharing options...
two40 Posted July 10, 2002 Share Posted July 10, 2002 i knew there was a reason why i wouldn't fork out $300+ for a disadvantage:rolleyes: Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29616 Share on other sites More sharing options...
HEL-RZA Posted July 10, 2002 Share Posted July 10, 2002 RPM i have the turbo smart plumb back BOV and it still has the stalling problem. i read some of the other posts in the forums and their seems to be a couple of theries and a few sollutions. one way i tryed was to adjust the idle. it seems to work but now she idles @ about 900rpm. is this too high for idle? can this cause any damage to motor? fuel economy dosent seem to be affected too much can still get around 400 k's a tank. Also before i adjusted the idle it seemed to be very lumpy. having a range of about 500 - 750rpm. Is this common in early model lines? (i have a R32 GTST) i have heard that this can be caused by a damaged or faulty AFM. Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29737 Share on other sites More sharing options...
AndyMac Posted July 10, 2002 Share Posted July 10, 2002 Listen, There's heaps more people on these forums who know a ****load more then I. But I'll give it ago. And I have Noooo problem being corrected by someone who knows better. The 900rpm Idle should be fine, I think there suupose to idle between 700-900rpm, mine idles at 900 all the time with no problems at all. The stalling could be a number of things, but since this is a post about BOV's, I'd check all the lines on the BOV and make sure the piston is releasing at a correct pressure...If the spring is rooted which holds the piston closed under boost is weaken it could leak and stall the same way as a Atmo one does. If the AFM is suspected its something for an expert, as it could cuase the car to run ultra rich or super lean, the later being the worse, as lean equals an expanding piston and an expanding piston can really screw your day up. That could be going to extremes there.... As for the lumpiness of the RB20DET, not sure, I'm got the RB25DET and the few mechanics I know have always commented how smooth the Nissan Engines are. I'd check all your spark plugs, ignition,and AFM if shes rough. Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29750 Share on other sites More sharing options...
HEL-RZA Posted July 11, 2002 Share Posted July 11, 2002 Cheers RPM Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29954 Share on other sites More sharing options...
diduc Posted July 12, 2002 Share Posted July 12, 2002 i have the turbo smart plumb back BOV and it still has the stalling problem. plumb back doesn't work? bout to trade my Turbosmart type 2 bov for a type 3 cos the guys at CAS says if u incurred problems with stalling, buy a type 3 or other similiar bov. mine's stalled occasionally now but was stalling heaps after i installed the FMIC, thanks to the Unichip. mine revved to 1200rpm when starting te car and settled to 900rpm. Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-30601 Share on other sites More sharing options...
UNREAL Posted July 29, 2002 Share Posted July 29, 2002 Yeah, that is a very common problem. I've tested quite a few brands and they all cause the car to stall if you leave the clutch in after a high rpm gear change. You probably blow black smoke and use heaps of petrol as well. Hybrid valves help but do not always cure the problem. Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-37387 Share on other sites More sharing options...
Doctor Posted July 30, 2002 Share Posted July 30, 2002 The reason why, is called reversion. What happens is the BOV is alot tighter than the factory one, so when the aftermarket one open it does not let out all the air and some of it passes out through the airfilter. Before it passes out the airfilter it cools the AFM element down and the computer reads this as the car is using more air and compensates for the amount of fuel going into the engine, hence the engine going into a rich condition for a second. Doc Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-37896 Share on other sites More sharing options...
XrSiSt Posted July 30, 2002 Share Posted July 30, 2002 thanks for the explanation Doc. But then if it's too lose, you lose boost? I guess it's a win lose situation, only win win is a plumback? Link to comment https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-37924 Share on other sites More sharing options...
