I have been mucking around with the BOV and now it sounds like ****!.
Im not sure on wether to tighten it or loosen it, If its to tight then it wont release the boost until its too high and too loose it will lose preasure.
It used to sounds really good but now :D it sounds crap now, wish i never touched it but curiosity got the best me.
Any ideas please how to get it hissing pssssstttt nicely once again
thanks
https://www.sau.com.au/forums/topic/1370-bov-how-tight/
Last night comnig home from work, I couldnt stand it anymore so i pulled the BOV off and pulled it all apart.
It was really dirty so i cleaned it all up oiled it and put it back and noticed that the pipe that runs from the BOV to the Bleed valve was torn where it connects to the BOV so i cut it and put back on.
!!!!!!AND IT WORKS!!!!!!!!
:lol:
The problem seems to have been the torn pipe but after the cleaning and oiling of the BOV it sounds better.
Have to see if it stalls now, hopefully not
https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29239
Its a very common problem with Atmo B.O.V's
When the inducted air is taken in the Air Flow Meter reads the amount and adjusts the fuel delivery to suit that amount of air. The BOV releases the same air that the air flow meter "thinks" has been mixed with the fuel.
So basically the computer injects the fuel but the air has vented out of the BOV, which causes the engine to "run rich". When the mix isn't right and its too rich the engine stalls.
Like the factory unit, a "plumb-back BOV" recirculates the air back into the system, thus equalizing the air/fuel ratios again.
Apart from the sound there is no clear advantge that i know about from having a Atmo BOV. Probably disadvantge.
https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29247
RPM
i have the turbo smart plumb back BOV and it still has the stalling problem. i read some of the other posts in the forums and their seems to be a couple of theries and a few sollutions. one way i tryed was to adjust the idle. it seems to work but now she idles @ about 900rpm. is this too high for idle? can this cause any damage to motor? fuel economy dosent seem to be affected too much can still get around 400 k's a tank.
Also before i adjusted the idle it seemed to be very lumpy. having a range of about 500 - 750rpm. Is this common in early model lines? (i have a R32 GTST) i have heard that this can be caused by a damaged or faulty AFM.
https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29737
Listen, There's heaps more people on these forums who know a ****load more then I. But I'll give it ago. And I have Noooo problem being corrected by someone who knows better.
The 900rpm Idle should be fine, I think there suupose to idle between 700-900rpm, mine idles at 900 all the time with no problems at all.
The stalling could be a number of things, but since this is a post about BOV's, I'd check all the lines on the BOV and make sure the piston is releasing at a correct pressure...If the spring is rooted which holds the piston closed under boost is weaken it could leak and stall the same way as a Atmo one does.
If the AFM is suspected its something for an expert, as it could cuase the car to run ultra rich or super lean, the later being the worse, as lean equals an expanding piston and an expanding piston can really screw your day up. That could be going to extremes there....
As for the lumpiness of the RB20DET, not sure, I'm got the RB25DET and the few mechanics I know have always commented how smooth the Nissan Engines are.
I'd check all your spark plugs, ignition,and AFM if shes rough.
https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-29750
plumb back doesn't work?
bout to trade my Turbosmart type 2 bov for a type 3 cos the guys at CAS says if u incurred problems with stalling, buy a type 3 or other similiar bov.
mine's stalled occasionally now but was stalling heaps after i installed the FMIC, thanks to the Unichip.
mine revved to 1200rpm when starting te car and settled to 900rpm.
https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-30601
  • 3 weeks later...
The reason why, is called reversion.
What happens is the BOV is alot tighter than the factory one, so when the aftermarket one open it does not let out all the air and some of it passes out through the airfilter.
Before it passes out the airfilter it cools the AFM element down and the computer reads this as the car is using more air and compensates for the amount of fuel going into the engine, hence the engine going into a rich condition for a second.
Doc
https://www.sau.com.au/forums/topic/1370-bov-how-tight/#findComment-37896
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
