Hey,
I'm looking at starting go-kart racing as I'm sick of doing nothing on my days off work.
Does anyone here race or could give some pointers about getting started up?
I am looking at probably buying an Arrow Kart, AX8 28-30
As seen here
And a Yamaha KT100S motor...
My only concern is that i'm quite tall (194cms) and not too sure about how I would fit.
If someone has some info on licences too than that would help.
Thanks.
https://www.sau.com.au/forums/topic/137012-go-karts/
' date='2 Oct 2006, 06:17 PM' post='2546127']
Hey,
As seen here
Thanks.
Go straight to your local Kart Club for all your info!
As for the height ....... well it all depends on how supple you are. I'm 180 and had little trouble. Arrow make an extended front bar etc which shifts the pedals further away. If you go that route, you will need to buy the longer floor pan as well.
cheers
Muz
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2555013
Mate you might struggle with the KT 100 engine better to go with electric start engine or get this one converted.
I am currently driving a 32 HP Biland twin cylinder 250cc 4 stroke and they are great fun or the smaller but stronger rotary engine which is 52 HP and 180 kg weight kart and driver plenty of brown pants moments in that little beast
Edited by tacker
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2595172
There is a dedicated kart forum here.. http://www.kartingaustralia.com.au/forum/index.php
As for the height, no idea, im the opposite end of the scale, over 1 foot shorter than you!
How much do you weigh is going ot be relevant to class. Also look at something which is raced competitively locally.
Licences are just a case of paying money. I think its cheapest in qld at $240 or $260 (one of the two)+ club membership. They are fairly expensive, but more comprehensive than a cams 2s or similar.
Once again chassis size (e.g 28/30 etc) will depend on class and height.
I wouldnt go rush out and buy brand new gear, just because a brand new S motor isnt going to be competitive without blueprinting, something used and proven might be better there. That said you would want something competitive and not some rubbish that someone is trying to offload on ebay.
Best bet would be to find a local kart shop or go to the track and talk to people.
Where are you locateD?
Edited by Turbo Tim
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2596987
And if you are going to get a used KT engine check the piston size as it may be up into its last size piston and then its a new barrel.
And make sure it is a sellect barrel or you are going to be a few hp down. If you can get it get very low port timing and close splits in the two port timings
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2597017
Hey,
good pointers .1 dont start playing with karts .its like a drug and u will get hooked.
2 try it in the rain.
karts are mad fun . good luck.
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2598797
hey there i been racing for about 4 years now quite competitvely travelign to differnt major meets around aust id suggest you go for a class which would hav the most numbers, as the guy was sayign he races a biland depending where you are you wont get as many people racing id reccomend either the J class Senior national light or heavy or Clubman light or heavy i currently race in clubmant light as i belive its the most competitive classes out there or one of them. to date my best finish would be 6th in the 05 nationals in western australia, this is a pic of me in the wa states 3 weeks ago
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2619092
Karting.
Absolutely the most fun you can have without going insanely quick.
Have you driven a go-kart yet? It's totally different to driving a car (Thrown around, bumps etc)
If you're in Sydney/Wollongong area, head up to the picton race way.
https://www.sau.com.au/forums/topic/137012-go-karts/#findComment-2622363
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
