Hey guys my r33 parkers have just stopped working.
both of them wont turn i i have checked all the fuses i can find and
also replaced the bulbs , carnt see why they have stuffed up as i have not
dont anything to the car.
is there anything i need to pay attention to ,is it common.
any help wil lbe great as my fault finding will take some time.
cheers
https://www.sau.com.au/forums/topic/137028-r33-s2-parkers-not-working/
cheers
Hey man you may possibly be looking at a relay or maybe even the light swithch/stalk itself.... do your rear tail lights still work when switching the parkers on?... if so then its unlikely the switch and u can concentrate more on wiring, relays or even just contacts somewhere... sometimes seemingly unrelated components are on the same circuit and can be causing the problem... its just different that you havent blown a fuse... good luck with it man :P
check with a multimeter - preferably down the backs of the plugs if you can...
one of my parkers blew, when i went to replace it there was all this white gunky shit inside the plug looks like maybe something nissan put in there to prevent corrosion - it was stopping the new parker from lighting up properly too (it would go on and off when i wiggled the plug). i belted the inside of the plug with contact cleaner and some dry air and then put the new parker in and it worked perfectly.
Definatley probe down the back of the plugs man... unfortunatley without a wiring diagram its gonna be hard to follow the circuit without ripping your car to pieces... better off starting at the globes themselves and working you way back...
woot fixed it ,the new ledone run a diode in them so they are polorized but i carn explain the old led
ones must have dies. are well all good ,thanks foryourhelp dished :D
No problem man good to hear you found out what was happening!
