nice, who did the remap?
i have the same prob with the 32 now.. cant seem to tune any more midrange in
dr drift came down for a week :ermm: , i chucked some cam gears on it and a boost tee (and a z32 afm) so now it has full boost around 3-3500rpm ish, its still all or nothing. im now dicing up whether to put an ext gate or go for a hi flow like you have now (and some bigger injectors :laugh: )
  • Replies 108
Posted Images
  • 3 weeks later...
:sorcerer: , sooooo i broke out the psyc wing but the only thing it psyked was me :(, stuffed another gearbox (jumps outta 3rd :happy: ) and have gone from a poor h/brake to absolutely none lol, it ok she's up on ramps now getting some much needed luvin :laugh:
  • 5 weeks later...
  • 1 month later...
ended up keeping her :sorcerer: , it still has the gearbox problem but ive stopped it from jumping outta 3rd (for the time being), still no h/brake but who needs it lol . heres some pics from the last drift day, its gunna be sttripped and painted now :D
update: just purchased a low klm rb25de gearbox, front guards some stocko bars for rego and a complete black trim, also coming is a 1 piece tail shaft and gtr injectors :P , then its onto the suspension & brakes :( . forgot to say i cracked a rim too so ill most likely be buying a new set , she needs some dish :)
Edited by toffy
  • 3 months later...
That should liven her up a bit :)
Going to keep the A31 loom/ecu etc? The R33 ECU's are much nicer to tune, especially with the mappable VCT etc... but add some cost :(
yeah lots of work ahead of me :P , not sure on which way to go regarding the ecu, im gunna send you a nice long email soon explaining the situation/options :wub:
lol nice one buying a whole car...
25's are the bomb!
lol, easiest way if getting all the parts i wanted :P... oh i cant wait :/
  • 1 month later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
