  • 5 weeks later...
  • Replies 108
Posted Images
Well i didn't make the last drift prac , but it is running , All i'm waiting on is finding my front pipe that is mia . I'm going to splash out on some new rims as soon as my 34 sells , i'd like some sp1s' but i doubt i'll find a set in the offset i want . here's a couple pics of me seeing what the stitchs' will look like (which i don't like)
Looks tough with em on, wouldnt mind seeing a side on shot. I do like the black pair ya had on the back but im just a sucker for black rims. haha.
Nice looking car man, i need a chrome grill !!!!!
Cheers mate! , they are definately better than the std r33 rims that were on it , the black ones are r33 gtr rims (my skid rims) , i have a side on pic , i'll put it up :) .
Did some more work on the old girl tonight , I fitted a rear reo , dummy fitted my rain visor thingys , fitted (kinda) a stereo , trial fitted some non-projector headlights , test fitted the fk rear bar and tidied up a few small things , i'm a bit dissapointed the non projectors are broken in spots , un-expectedly , i like them , i'll fix them up i reckon . pics
Side pic of rims.... = PORN! hahaha, look good dude. I thought the black ones on the rear where 33 gtr wheels, hard to tell with em painted black.
Are those rain visor thingys the ones off ebay?? Im gonna get some myself, i think they look the part and should suit my car... Especially when i fit up my roof spoiler!
Keep up the good work!
Cheers mate , yeah the shields are the ebay ones , not the best fit , but better then nothing! , in case you're wondering , they're not see through either (like the factory ones). Picked up a front pipe today , it's a full front/dump but i'm putting a std turbo back on it asap anyway (for rego , plans are to make it road legal asap so i can finally do what i want with it) mind you i want to use it at power cruise this year so i'm under a bit of pressure to get it up and ready pinch.gif .
fitted all the front back up to standard/old man spec , i found out i had those side clips already on the bar (the ones like nica31 put a thread up about) , i pinched a pair off the other blue one which will now go on the white one! since i didn't need them :P
And i trial fitted some side skirts i got with the std bars , i kinda like them but it needs a lower front bar , i might try add a lip to the missile front bar :) , pic: (you can't really see , i'll put better ones up later)
  • 1 month later...
Yeah I've had it a while , i really should have registered it years ago! Oh well , stock rb25turbo is now fitted , i need to get a whole bunch of stuff engineered because it has to go over transport because it needs to be complianced , only issue is the coilovers , not sure they will pass
  • 2 months later...
Ok up for sale she is , what do you guys think it's worth? Mod list to date :
engine : rb20det , gtr injectors , power fc , 3in full exhaust , td06 sl2 20g 8cm (kando) , cam gears , z32 afm and a few other small things , needs a tune , very healthy motor .
Rb25 Gearbox , 2 way , coil overs , gtr sway bars , rear camber arms , front castor adj rods , 5 stud , recaro seat . Uncomplianced but very close to being done . Comes with standard bars and final konnexion kit and a spare uras kit if wanted . I want to put lots on it but i doubt i'll get it . Or i could put it back to stock , sell the goodies and sell it cheaper?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
