i was goin 2 use this box for my car and have a ppg dog gearset fitted but seeing i cant move my os box this is now up 4 sale...
all smooth i personally tested it in a running car b4 i bought it, the gtr had approx 60k on it and it was standard the whole time. no crunching or noise
$1300 ono
sydney
https://www.sau.com.au/forums/topic/137063-r33-gtr-gearbox/
it will altho u will need the push pull converter for the clutch as the clutches are different. i do still have my OS giken 5spd gearset box 4 sale..
Edited by MR MAD
https://www.sau.com.au/forums/topic/137063-r33-gtr-gearbox/#findComment-2547908
  • 3 weeks later...
