Thats cool Gareth, i see your point...
But if people have tested it (more than once), shown there to be less than 10rwkw in it which is far from something to get excited about
That how does that come about? How does that get explained?
  • Replies 72
Some cs student you don't know what your talking about do you. Whats that. No No you don't. I don't get how some of you don't get it. How can a transfer case tranfer more than 50% of the torque to the front wheels when it is the same final drive ratio as the rear and the rear drive line is fixed to the engine when in gear. It can't. Never will.
I never said it was transferring more than 50%.
I meant more as in it will transfer more power to the front wheels than a standard transfer case would at a given amount of slip, ie. if it was trying to transfer X amount of power a modified transfer case would give it a little more.
EDIT: so it would reach the so called "50%" if that is the case, a little faster than a non-modified transfer case due to the change is clutch plates.
Furthermore, since your referring to the torque split gauge as a percentage you clearly don't know what your talking about there, it's not a percentage.
Your point about the clutch plates compressing is noted, as as most of your points, but you don't need to come across so arrogant in your posts.
EDIT: On second thought, I haven't slept for a few days so maybe I'm the one mis-interpreting, I guess I'll find out from your next post.
Your "locked" made me think of how a 2-way diff locks at a certain amount of torque going through it, I now understand what you are referring to as "locked" makes sense now, simply a mis-interpretation there.
To prevent confusion please make it clear which Gareth your referring to, I can see your referring to Rowdy32 in that post (I think) :P
Exactly right with the transfer case workings.
I wasn't talking about the torque gauge on the dash as it is only what the computer thinks it is transfering to the front by the amount of pressure it is putting on the clutch. If the transfer case is rooted the gauge displays what it thinks its doing but in reality little drive is going to the wheels. On a 4wd dyno screen there is a display that shows the amount of torque going to the front and rear rollers. Thats what I'm talking about. One of the ways of telling if your case is rooted. The gauge in the dash is really only good for wank value and I don't think I have ever even looked at it whilest driving. You can normal tell if its locking up by how the car handles also.
Ah, interesting, I just had to replace my transfer case as it had some issues (badly slipping and the shaft (?) inside it was making a grinding sound), a 4WD dyno would be an interesting way of confirming the second-hand one I got doesn't have issues...
Thanks for the info.
  • 2 months later...
There is a turbo in the Garrett range between the -5 (GT2860R 62 Trim) and the -10 (GT2871R 52 Trim), that being the GT2871R 48 Trim. Garrett has rated it to 400HP (they rate the -10 to 460HP), i was wondering if anyone has ran one of these on a GTR as i can imagine they would be a lot more responsive than the -10 and would yield a lot more power that the -5. To run on of these though you would have to get Garrett to modify a -5 compressor housing to fit if you want to retain the factory piping but they would be will to do it and I wouldn't imaging it would cost much.
GT2871R 48T 400hp
http://www.turbobygarrett.com/turbobygarre...1R_743347_1.htm
Vs'
GT2871R 52T-10 460hp each
http://www.turbobygarrett.com/turbobygarre...R_707160_10.htm
I'm looking at building a RB26/30DETT at some stage in the not too distant future and i and seriously looking at running these on that as i imagine that the response of the 48Trim's on a 3 litre would be similar to that of a set of -5 on a 2.6 litre.
Edited by D_Stirls
  • 1 month later...
so are the -9's the middle man between the -7's to -5's?
i have 280rwkw @15psi with r34 turbos, cams big porting forged engine ect (stock afm's are holding me back)
im still trying to decide if i want to go up to the -5's the -7's dont seem worth it over what i already have but if the -9's make a bit more then the -7's with similar response...
i dunno haha
Edited by shy_s6
i dunno haha
afm wont be holding u back at that power.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
