Thats cool Gareth, i see your point...
But if people have tested it (more than once), shown there to be less than 10rwkw in it which is far from something to get excited about
That how does that come about? How does that get explained?
  • Replies 72
Some cs student you don't know what your talking about do you. Whats that. No No you don't. I don't get how some of you don't get it. How can a transfer case tranfer more than 50% of the torque to the front wheels when it is the same final drive ratio as the rear and the rear drive line is fixed to the engine when in gear. It can't. Never will.
I never said it was transferring more than 50%.
I meant more as in it will transfer more power to the front wheels than a standard transfer case would at a given amount of slip, ie. if it was trying to transfer X amount of power a modified transfer case would give it a little more.
EDIT: so it would reach the so called "50%" if that is the case, a little faster than a non-modified transfer case due to the change is clutch plates.
Furthermore, since your referring to the torque split gauge as a percentage you clearly don't know what your talking about there, it's not a percentage.
Your point about the clutch plates compressing is noted, as as most of your points, but you don't need to come across so arrogant in your posts.
EDIT: On second thought, I haven't slept for a few days so maybe I'm the one mis-interpreting, I guess I'll find out from your next post.
Your "locked" made me think of how a 2-way diff locks at a certain amount of torque going through it, I now understand what you are referring to as "locked" makes sense now, simply a mis-interpretation there.
To prevent confusion please make it clear which Gareth your referring to, I can see your referring to Rowdy32 in that post (I think) :P
Exactly right with the transfer case workings.
I wasn't talking about the torque gauge on the dash as it is only what the computer thinks it is transfering to the front by the amount of pressure it is putting on the clutch. If the transfer case is rooted the gauge displays what it thinks its doing but in reality little drive is going to the wheels. On a 4wd dyno screen there is a display that shows the amount of torque going to the front and rear rollers. Thats what I'm talking about. One of the ways of telling if your case is rooted. The gauge in the dash is really only good for wank value and I don't think I have ever even looked at it whilest driving. You can normal tell if its locking up by how the car handles also.
Ah, interesting, I just had to replace my transfer case as it had some issues (badly slipping and the shaft (?) inside it was making a grinding sound), a 4WD dyno would be an interesting way of confirming the second-hand one I got doesn't have issues...
Thanks for the info.
  • 2 months later...
There is a turbo in the Garrett range between the -5 (GT2860R 62 Trim) and the -10 (GT2871R 52 Trim), that being the GT2871R 48 Trim. Garrett has rated it to 400HP (they rate the -10 to 460HP), i was wondering if anyone has ran one of these on a GTR as i can imagine they would be a lot more responsive than the -10 and would yield a lot more power that the -5. To run on of these though you would have to get Garrett to modify a -5 compressor housing to fit if you want to retain the factory piping but they would be will to do it and I wouldn't imaging it would cost much.
GT2871R 48T 400hp
http://www.turbobygarrett.com/turbobygarre...1R_743347_1.htm
Vs'
GT2871R 52T-10 460hp each
http://www.turbobygarrett.com/turbobygarre...R_707160_10.htm
I'm looking at building a RB26/30DETT at some stage in the not too distant future and i and seriously looking at running these on that as i imagine that the response of the 48Trim's on a 3 litre would be similar to that of a set of -5 on a 2.6 litre.
Edited by D_Stirls
  • 1 month later...
so are the -9's the middle man between the -7's to -5's?
i have 280rwkw @15psi with r34 turbos, cams big porting forged engine ect (stock afm's are holding me back)
im still trying to decide if i want to go up to the -5's the -7's dont seem worth it over what i already have but if the -9's make a bit more then the -7's with similar response...
i dunno haha
Edited by shy_s6
i dunno haha
afm wont be holding u back at that power.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
